P0335 code. Not obvious fix. help
Old Aug 7, 2012 | 03:47 PM
k6750gsxr's Avatar
k6750gsxr
Default P0335 code. Not obvious fix. help
Hey guys I am having a crazy issue that I cant figure out. Any help is appreciated...
I just swapped motors in my z from my built motor to a OEM motor. When I went to start the car it was having hard cranking issues. Then it through a p0335 code. It was running like poop and missing really bad. I replaced the crank sensor. Still running the same. Any one else ever seen this issue or have any suggestions.
Thanks
Old Dec 13, 2012 | 01:09 PM
k6750gsxr's Avatar
k6750gsxr
update on this for any one it may help in the future.
When i re installed the trans to the new motor I bent the drive plate some how. The crank sensor was not reading correctly causing the hard start and miss fire.
So if this ever happens to you. Make sure your crank sensor is lined up and reading right.
aarrgghh
May 1, 2022 11:04 AM
350z_z33.
Jul 3, 2017 04:01 AM
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
