Car is losing power going around turns
Old Aug 12, 2012 | 04:53 PM
JMarleyboo's Avatar
JMarleyboo
Default Car is losing power going around turns
My first post so please don't be too brutal. I have a 2006 touring. Replaced the tires about a year ago and ever since, when I go around a turn the slip light comes on and the car looses power. I keep my foot on the gas and it will eventually reengage once I get out of the turn.
Any suggestions on the cause/what to do? I am a not a motorhead so please don't get to mecho-techno. Tx.
Old Aug 12, 2012 | 04:59 PM
pbgrep's Avatar
pbgrep
This never happened before???? Any time I mash the gas on a turn the traction control always kicks on and does that, its what its supposed to do... I just turn my traction control off and im good to go, but I believe yours has VDC so one of those guys will have to chime in
Old Aug 12, 2012 | 05:00 PM
DavesZ#3's Avatar
DavesZ#3
Wrong size tires.
What are the specs on front and rear tires?
BTW - it was all explained here... https://my350z.com/forum/showthread....1&postcount=45
Old Aug 13, 2012 | 03:42 AM
Phenom's Avatar
Phenom
Toasty
Aaaand this is the first step in creating a "my car is upside down in a ditch" thread.
Old Aug 13, 2012 | 05:09 AM
Italianjoe1's Avatar
Italianjoe1
Put the proper size tires back on the car. Problem solved.
Old Aug 13, 2012 | 07:24 AM
pbgrep's Avatar
pbgrep
its called learning to drive... there was a time when traction control, vdc, etc.. didnt exist. If you know how to drive your car, no one should end up in a ditch
Old Aug 13, 2012 | 08:27 AM
Duckeee's Avatar
Duckeee
turn off traction control? lol
it's kicking in when you're about to lose traction and cuts the power.
Old Aug 13, 2012 | 08:43 AM
tylerxfire's Avatar
tylerxfire
ppl read and give useful info, if you dont have useful info dont try..he said slip light comes on..it is most likely due to tire sizes
Old Aug 13, 2012 | 08:55 AM
realist alive's Avatar
realist alive
Old Aug 13, 2012 | 09:27 AM
Chebosto's Avatar
Chebosto
Originally Posted by JMarleyboo
mecho-techno. Tx
OOnce OOnce OOnce Yeeehaw
Old Aug 13, 2012 | 10:13 AM
F34RL355's Avatar
F34RL355
slip light comes on when u lose traction.... would he not be getting slip in the straights if it was wrong tires size?
Old Aug 13, 2012 | 10:19 AM
tylerxfire's Avatar
tylerxfire
maybe it flashes idk, i never run with the trac. control on..he is saying the car is losing power and the slip light is coming on permanantly from what i gathered..which would point to wrong tire sizes
Old Aug 13, 2012 | 10:49 AM
F34RL355's Avatar
F34RL355
my slip light stays on permanent if i do some donuts with stock size tires. i do this every time i need a new set lol
Old Aug 13, 2012 | 10:51 AM
tylerxfire's Avatar
tylerxfire
imo that is not normal but idk..mine have never done that...check ur brake fluid
Old Aug 13, 2012 | 11:12 AM
Phenom's Avatar
Phenom
Toasty
So was there ever a time when "mashing the gas in a turn" was a good idea? None of the people in the ditch thought that's where they were headed either.
Old Aug 13, 2012 | 12:03 PM
Esser's Avatar
Esser
This is only due to incorrect tire sizes or stagger. He is not spinning his tires or losing traction. When the rear wheels are turning faster than the front (at a certain percentage) then the slip light will come on and the power will be cut from the engine. It is both cutting fuel and trickling the rear brake.
This will only occur during a high speed turn because the rear diff is unloading and causing the outer most tire to turn faster than usual, which will go beyond the allowed percentage allowed before traction control kicks in. Your car thinks your wheels are spinning but they are not. Get the proper sized tires and this will not happen. You need to maintain a factory stagger on your tires for this not to occur
Old Aug 13, 2012 | 12:51 PM
pbgrep's Avatar
pbgrep
Sounds pretty official to me.. I would go with this guy. New tires it is!
Old Aug 13, 2012 | 12:56 PM
Duckeee's Avatar
Duckeee
before replacing the tires, please post the size of the tires and perhaps the wheel sizes as well.
Old Aug 13, 2012 | 02:01 PM
Esser's Avatar
Esser
Agreed. Post up your current setup and we can guide you in the right direction depending on what size wheels you have.
Also, if you didn't know you can turn off the VDC or TCS and this will not happen
etkms
Jun 19, 2022 06:30 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
Daniel_dh
Sep 7, 2015 12:56 PM
