Small crack in tail light
Old Sep 1, 2012 | 09:52 AM
phased1's Avatar
phased1
Default Small crack in tail light
Hello I just purchased a 04 350z, but it has like a two inch crack in one of the tail lights and water gets inside. Is there a way for me to fix this or will I have to just replace it? Thanks.
Old Sep 1, 2012 | 10:06 AM
GLRacing's Avatar
GLRacing
pics
Old Sep 1, 2012 | 10:27 AM
phased1's Avatar
phased1
Originally Posted by GLRacing
pics
Sorry here you go.
Old Sep 1, 2012 | 11:30 AM
GLRacing's Avatar
GLRacing
as far as i know, there is no way to fill a crack besides the use of tape. I know that there are ways to fill in a missing piece of the lens, but I would just replace the entire light in your situation. There might be a way to disassemble the taillight and use some sort of epoxy to seal the crack from the inside, but the unsightliness of the crack would still be there, and I wouldn't be sure if you can take it apart anyways unless i actually looked at my own light(: good luck.
Old Sep 1, 2012 | 11:38 AM
JCITY's Avatar
JCITY
Several options...of course one is to replace.
The other(my suggestion)is to purchase a vinyl overlay for the lights.
Is the surface by the crack even?If not,you could sand or file it down
a bit.
Besides covering/fixing the crack,if you get a smoke tint,it'll look cool.
Several places on e-bay that sells them.Easy install.
Old Sep 1, 2012 | 11:44 AM
phased1's Avatar
phased1
a bit.
Oh okay. I was planning on smoking them but I thought I had to fix this crack first since water is still inside it. I guess I can take it apart wipe the water then vinyl it no problem?
Old Sep 1, 2012 | 12:41 PM
STL 350Z's Avatar
STL 350Z
Taking it apart might be more of a chore than anything and you have to make sure you seal it back up when your done. My passenger side tail is getting water in it somewhere and I am unable to locate where exactly... I plan on sourcing a replacement or purchasing new 06+ tails.
Good luck with whatever you choose to do.
Old Sep 1, 2012 | 02:16 PM
Waiz's Avatar
Waiz
Replace it, if it's not an LED set you can get a one off the forum very cheaply
Uriyo_
Sep 8, 2021 08:46 AM
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Nov 9, 2015 11:10 AM
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
