CLUTCH QUESTION !!! 6speed manual
Old Sep 11, 2012 | 11:20 AM
Colourdeaf's Avatar
Colourdeaf
Default CLUTCH QUESTION !!! 6speed manual
Hey guys,
I have a 2005 Nissan 350z 6spd with a manual tranny
The problem: I went into Mister Transmission and they took my car for a test drive and said this: there is too much play within the clutch/ pressure plate seems to be gone bad and the release barring must be too.
The Question: he suggest a clutch assembly kit, with a clutch disk/release barring and pressure plate, Should I buy all that or just the pressure plate individually AND does anybody know a cheaper brand of clutch disk kit although still decent for the price in CANADA/USA..... I was qouted 400 bucks for the kit from him AND 450bucks labour.....
The second question: What will happen if i continue driving with the problem
help !!!!
Old Sep 11, 2012 | 02:45 PM
musubi's Avatar
musubi
What was the reason for taking the car in (what was the problem you observed)?
Maybe I'm just not that mechanically knowledgeable on what the issues could be based on what the mechanic said, but if their going to replace the pressure plate, they might as well replace everything. I'd say, replace the clutch assembly, release bearing, and flywheel too. $400 for the stock clutch kit sounds cheap actually. I was quoted $800 for a new stock clutch from the dealer, without labor. Are they replacing with stock or an aftermarket kit?
Old Sep 11, 2012 | 05:26 PM
hellman_x's Avatar
hellman_x
Buy a JWT, it's almost like OEM and will last longer.
Old Sep 11, 2012 | 05:27 PM
Colourdeaf's Avatar
Colourdeaf
i have a friend with a used 50,000km clutch disk + pressure plate.. i might as well just buy that from him and have it installed,
problem is, i need to wait a second and let the clutch out slowly which is annoying
Old Sep 11, 2012 | 07:22 PM
brianmullanl's Avatar
brianmullanl
Old Sep 11, 2012 | 07:46 PM
VqBrickYard's Avatar
VqBrickYard
OP, does it happen for every gear or just some? ..
Old Sep 11, 2012 | 08:09 PM
Colourdeaf's Avatar
Colourdeaf
mostly from first to second, but there is play in the clutch before it engages like he test drove it and was clicking in the clutch a bit and it didn't shake the car at all
Old Sep 11, 2012 | 08:24 PM
VqBrickYard
Yes sounds similar to my issue, I pretty much replaced my whole clutch, with a southbend it came with throw out bearing pivot ball along with a few other things. Got the car back ... the clutch pedal was weak like crazy checked out few things found leaking my slave and master cylinder that pretty much made the car drive brand new almost. Maybe that's your problem?
Old Sep 11, 2012 | 08:26 PM
VqBrickYard
Check that ... I replaces those two components and it helped out tremendously ***
Old Sep 14, 2012 | 06:24 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
It will not last any longer than an OEM clutch, It "IS" an OEM clutch disk with a heavier pressure plate.
Old Sep 14, 2012 | 09:00 PM
hellman_x's Avatar
hellman_x
Lol, don't know why I said JWT, I meant to say ACT. I have an ACT clutch and lightweight flywheel and it almost feels like stock.
Old Oct 16, 2012 | 08:15 AM
wizard's Avatar
wizard
Reaaallllyyy?
Heavier pressure plate means it's able to hold more power?
Old Oct 16, 2012 | 09:16 AM
ZSpeedPerformance
Look at the disk, Says NISSAN right on it. Order a stock nissan disk and compare for yourself.
issyz
Jul 2, 2017 03:04 PM
Li1ag
Sep 28, 2015 02:07 PM
Tochigi_236
Sep 27, 2015 03:40 PM
