after refueling car sputters then goes away after 5 min
Old Sep 19, 2012 | 07:00 PM
realist alive's Avatar
realist alive
Default after refueling car sputters then goes away after 5 min
Consistently after refueling I start my car and it idles funny ex. "put put put" sound coming from exhaust (noticeably different exhaust note). RPM gauge does not rise or fluctuate radically. when I hit the gas there is slightly less power from engine. typically shortly after I get somewhere safe to pull over it goes away, and doesn't return till i refuel. no check engine light comes on so I cant pull codes.
Current Mods: plenum spacer, JWT pop charger, non resonated test pipes, ARK Grip v2 exhaust.
car is a 2003 with 80k miles. I purchased it bone stock with 65K miles and this problem did not occur. I have heard about leaks from the plenum spacer causing a engine sputter, and Faulty spark plugs or injectors causing this type of issue.
What does everyone think? I know there is a sticky with a similar topic but my issue comes consistently after I put gas in the car. I mean right after, as soon as i start the car before i pull off the gas station property. I use shell gas typically and always use premium. and it doesnt matter if i fill it up or only put a couple gallons in.
Old Sep 19, 2012 | 09:20 PM
RandyK1's Avatar
RandyK1
Vent tube blockage on the gas filler neck????
Old Sep 19, 2012 | 09:46 PM
kacz07's Avatar
kacz07
All these mods and no tune?
Old Sep 20, 2012 | 10:29 AM
realist alive
Tune will be happening before christmas. Just making sure im content with plenum spacer, or do I want tto upgrade to actual plenum.
I will look at the fuel vent tube this weekend
Old Sep 20, 2012 | 11:24 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Huh, I have the same problem, after a recent tune on my Haltech. Plenty more mods on my car, as well. No idea what the solution is, or what is causing the problem.
Here's my thread on the issue
Old Sep 20, 2012 | 02:07 PM
realist alive
just read your thread it sounds like we have the exact same issue. i will be changing the spark plugs, and checking the fuel filler vent hose. then getting a Osiris tune from z1 motorsports. I will keep updating if anything changes.
Old Sep 20, 2012 | 02:43 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Yeah, if I find a cure, I will let you know as well
Old Jan 7, 2013 | 03:44 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Well, found out what my problem is, although it won't sole your issues, it might give you a hint: in my Haltech map, the values for the EVAP were all corrupt, including the inactive O2 and the active O2. So, for you, this might mean that you have some issues with your evap canister. Not sure, but at least wanted to let you know.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
