2006 350z problem: ABS, Brake, TCS, and SLIP lights on
Old Oct 21, 2012 | 07:30 PM
Allen350z's Avatar
Allen350z
Any help on the Tcs,ABS,Brake,and Slip light issue after getting an alignment
Old Oct 21, 2012 | 07:33 PM
Allen350z's Avatar
Allen350z
Can u look at post 20 and 21 to see if u can help
Old Oct 27, 2012 | 01:41 PM
PeterPotatoes's Avatar
PeterPotatoes
Originally Posted by Allen350z
Had my car aligned the other day,when they pulled it off the rack the tcs,abs,brake, and slip light came on cant find the problem, any help. I also got it home and put it on the lift, started the car put it in neutral rolled the front wheels by hand and it made lights come on again. Turned it off started it again rolled the back wheels they didn't come on
2004 350z
You should make your own thread, but since the OP hasnt responded in a month... If one wheel speed sensor is notice and non of the other wheels are moving the car is going to think there's a problem with that one wheel sensor. You said the lights came on again, so they turned off, right? I wouldnt worry about codes unless you're driving down the street and the lights come on and stay on. If the lights are staying on, start your own thread and give trouble codes
aarrgghh
May 1, 2022 11:04 AM
reno56
Interior
17
Nov 20, 2015 05:21 PM
nissan1310
Oct 12, 2015 08:54 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
RyansZ33
Sep 15, 2015 05:54 AM
