HR Starts then stalls/dies
Old Sep 29, 2012 | 05:27 PM
John_B's Avatar
John_B
Exclamation HR Starts then stalls/dies
I've read a few threads and none of them seems to help.
Completed:
ECU Reset
TB position reset
Cleaned MAF and TB.
I can hear the TB position itself after I take the key to OFF position.
I can here the pump when I turn the key to ON position.
Filled up the gas close to half a tank early morning, and for some odd reason I forgot to close the gas cap. I was still able to start the car after work.
Drove the car for some errands. Then when I got home a few hours later the car Starts then dies.
Anyone had this issue before?
Bad Gas?
Gas indicator might be off?
Fuel pump is dirty?
Bad Spark plugs
2008 HR 59k
Injen CAI
ART Pipe
Bassani exhaust
Old Sep 29, 2012 | 06:17 PM
xpertool's Avatar
xpertool
Did you check to c if your Cold air intake are loose at any point? Sometimes the silicon hose connection might come loose from vibration and large vacuum leak might cause your car to stall.
Old Sep 29, 2012 | 06:26 PM
John_B's Avatar
John_B
Yup, I re-tighten all the tube clamp when I cleand the MAF earlier before I started the car again.
Old Sep 29, 2012 | 07:41 PM
John_B's Avatar
John_B
Update:
Car would not even start now. It would crank but no go.
Old Sep 29, 2012 | 08:12 PM
R350Zz33's Avatar
R350Zz33
how did you clean the tb did you move the blades ?
Old Sep 30, 2012 | 07:46 AM
John_B's Avatar
John_B
TB CRC cleaner and just moved the valve with my hand.
Old Sep 30, 2012 | 08:25 AM
andre81k's Avatar
andre81k
Might have uncalibrated the throttle body if you moved it with your hand, but that only messes up the idle
Old Sep 30, 2012 | 09:21 AM
John_B's Avatar
John_B
I did the service manual TB calibration process after all the cleaning was done. (Battery was off prior to cleaning).
The car was able to start then stalled this morning, after that it would just crank.
I'm going to change the spark plugs in a few and add fresh gas. Hopefully the problem is very minor.
Old Sep 30, 2012 | 11:13 AM
John_B's Avatar
John_B
The code is reading P1233
Old Sep 30, 2012 | 11:18 AM
John_B's Avatar
John_B
P1233 Electric Throttle Control Function.
Old Sep 30, 2012 | 12:19 PM
John_B's Avatar
John_B
Bump!
Old Sep 30, 2012 | 01:18 PM
John_B's Avatar
John_B
FIXED!!!!!!!!
Driver side throttle body valve was stuck! Pushed a little harder to open it, put everything back together then boom car is back running.
Old Oct 1, 2012 | 06:58 PM
kramykram's Avatar
kramykram
I would be a little concerned if throttle is sticking. That is not normal.
Old Oct 1, 2012 | 07:29 PM
John_B's Avatar
John_B
I'm going to inspect it again tomorrow. I would assume it would only get stuck when the valve is close.
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Dymsi
Sep 29, 2015 11:32 AM
