Car dies after start
Old Oct 3, 2012 | 09:35 AM
brandon7219's Avatar
brandon7219
Default Car dies after start
Hey all. So the story is I'm ob my way home turn to go up a hill when all the sudden I lose all engine power. Pull off into a spot an try starting up again. Starts up for a couple seconds then dies. Then I tried again giving it gas to see if that's the problem and it seemed to die a little quicker then previously with no gas.
I open up the hood to find any *hopeful* immediate signs and see the my jwt filter is not even attached. It is sitting in the inlet hole on the frame. I reattach it and try it again. Once with no gas an once with gas. Again it seemed to die quicker trying to give it gas.
I am currently waiting for the tow truck to show up. Any guesses from you all?
Old Oct 3, 2012 | 09:40 AM
La_Fiebre's Avatar
La_Fiebre
Maybe Maf is bad
Planetwister's Avatar
Planetwister
Damn that sucks. Is there a check engine light? Maybe a sensor or fuel pump?
Old Oct 3, 2012 | 09:49 AM
brandon7219
Forgot to add that.
No CEL light. The Z has 80k on it. Only mods are the jwt pop charger and plenum spacer.
There are no immediate signs, nothing leaking on the ground no disconnected wires or lines that I can see.
Old Oct 3, 2012 | 01:25 PM
pbgrep's Avatar
pbgrep
squirrel crawled into your intake and made a nest which is now clogging your entire air intake, not likely, but it could happen.
Old Oct 3, 2012 | 02:54 PM
brandon7219
welp... upon further investigation it was the MAF. A piece of cotton was stuck to it. So alls well that ends well i guess. thanks for the inputs
lolwatbro
Oct 9, 2021 04:58 AM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
