Car starts and immediately dies, ideas?
Old Oct 7, 2012 | 06:57 AM
RA11325's Avatar
RA11325
Default Car starts and immediately dies, ideas?
The story:
Car drove perfect when last parked. Try to start about a week later and the car will start and immediately die. Pulled code p0345, replaced batter with new deka 18xtl battery and bank 2 camshaft sensor like the code dictates, still no change in condition, any ideas? Car also throws random abs codes, all lights on the dash are on.
Old Oct 7, 2012 | 10:01 AM
JCITY's Avatar
JCITY
At times both cam position sensors are bad.One shows uo with a code.The other is weak,ready to go.You replaced the harder to get one.The bank 1 is a piece of cake.
A bad sensor will make the codes go crazy like you are experiencing.Just my opinion...
I only use a OEM Nissan part when replacing a part like a cam sensor.I've known
aftermarket replacements to be defective.
Old Oct 7, 2012 | 12:07 PM
RA11325's Avatar
RA11325
I used oem, thanks for the input!
Old Oct 8, 2012 | 12:41 PM
Tackett's Avatar
Tackett
This happened to me once. Turned out I didn't push in the throttle body wire harness plug hard enough.
Old Oct 8, 2012 | 04:07 PM
coanan's Avatar
coanan
Antitheft system shutting down injectors?? just a guess
Old Oct 9, 2012 | 09:27 AM
RA11325's Avatar
RA11325
Bump, still stumped
Old Oct 9, 2012 | 10:08 AM
Neimad's Avatar
Neimad
Just to make sure, you replaced passenger side sensor?
FSM list of things to check:
Harness or connectors
CMP bank 2 open or shorted
CKP sensor shorted
EVT (exhaust valve timing) control position sensor B2 shorted
APP sensor 2 is shorted
EVAP control sys pressure sensor is shorted
Refrigerant pressure sensor is shorted
Camshaft mechanical issue
Starter
Starting system circuit
Easiest way to diagnose is with a good OEM datasream reading scanner and digital oscilloscope plus wiring diagram. Finding someone who knows how to is hard. Otherwise throw parts at it.
etkms
Jun 19, 2022 06:30 PM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
