Broken 350z air recirculation flap
Old Oct 8, 2012 | 09:29 AM
shift_Pvo's Avatar
shift_Pvo
Default Broken 350z air recirculation flap
Hello everyone,
Hopefully this isnt a first, hoping I can get some advice here.
Today i was tinkering around with the girlfriends 350z, replacing the battery tiedown and such.
I pulled a bit to hard on the air recirulation flap thinking it was removable and the female end snapped.
Anyone done this before? Advice? It seems that it was not designed to be replaced/removed/swapped so even if i purchased a replacement I would not be able to install it.
What do I do? Currently its left off so I guess the car is going to always be recirculating air and drawing in new air until its fixed.
Thanks in advance.
Pic 1: Bottom right hand corner you can see the snapped part
Pic 2: Grate in the upper part of the picture is what the flap was covering.
Old Jan 22, 2013 | 01:56 PM
shift_Pvo's Avatar
shift_Pvo
Hello?
I think this is affecting the blowing hot air. ie - bringing in too much cold air and not warming up as fast.
Old Mar 10, 2014 | 06:23 PM
shift_Pvo's Avatar
shift_Pvo
any thoughts people?
Old Mar 11, 2014 | 05:57 AM
KornerCarver's Avatar
KornerCarver
Here are the parts schematics from Courtesy Parts. It looks like the part may be available, but installation looks to be pretty difficult. You may even have to buy the complete blower unit.
http://www.courtesyparts.com/350z-pa...5_751_765.html
Old Mar 11, 2014 | 06:07 AM
iideadeyeii's Avatar
iideadeyeii
HAHA, a year and a half before someone responded
Old Mar 11, 2014 | 01:06 PM
zakmartin's Avatar
zakmartin
So has the car been without the door for the last year and a half? Damn! I'd at least get some epoxy and screen door mesh to keep all the outside garbage out of the fan. That kind of plastic is a pain to glue up, but a small piano hinge and a pop rivet gun might do the trick if you want to fix it Sanford and Son style.
Old Mar 11, 2014 | 01:48 PM
92K1500's Avatar
92K1500
Stuff would get in the fan either way. That flap just changes it from recirculate to fresh air.
In fresh air mode (any time you turn the a/c compressor off) that flap will be open just like it's not in there.
There really is no need to have it there unless you're in a very hot climate.
etkms
Jun 19, 2022 06:30 PM
Vigman
Nov 17, 2015 04:34 AM
