Roaring Tires
Old Jan 13, 2004 | 07:33 AM
Packloyal's Avatar
Packloyal
Exclamation Roaring Tires
my z has about 10k on it now. tire wear looks minimal, but they roar incredibly loud at around 5-20 mph. anybody else had this issue? perhaps the bearings have gone bad?
Old Jan 13, 2004 | 07:41 AM
JeffR116's Avatar
JeffR116
Default Re: Roaring Tires
Your tires are feathering.
https://my350z.com/forum/showthread....threadid=15758
Do you have an 03 or 04 Z?
Old Jan 13, 2004 | 08:11 AM
mickey's Avatar
mickey
Default Is it 03 or 04?
If your Z is '04, please share the VIN number(last 5 digits).
Thanks,
Old Jan 13, 2004 | 09:25 AM
Packloyal's Avatar
Packloyal
it's an '03. it appears that my car doesn't fit the date/VIN parameters for the tsb...but there's no doubt that's what happening.
Old Jan 14, 2004 | 02:55 PM
peptidbond's Avatar
peptidbond
If you own a 2003 and you have roar when slowing from 30-5, then you are covered under a TSB. Make an appointment with the dealer to have your tires removed from the rims and rotated left to right (this is fine, despite the manual). Also, they will have to do an alignment. MAKE SURE TO GET your alignment specs before and after. You should get a print out. If they refuse, then you should use another dealer. Look at the print out and pay attention to the toe settings. They should be 2mm toe in with zero varience. If this is not what it says, then they need to do it again. For more info on this TSB and others, see www.nissan-techinfo.com.
Old Jan 14, 2004 | 03:22 PM
ares's Avatar
ares
Veteran
just curious; nissan wont be doing this for me Im sure; I wouldnt want them to on my aftermarket rims.
but does the 2degree toe in apply to aftermarket rims as well? I need to get mine checked before my new tires are messed up.
Old Jan 15, 2004 | 05:03 AM
MY350Z.COM's Avatar
moved
Old Jan 15, 2004 | 11:37 AM
bhobson333's Avatar
bhobson333
If your dealer gives you any problem, take it to Michael Jordan's RPM in Durham, ask for Pat. He'll fix you up.
You probably should go there for your service anyway. I wouldn't trust any other dealer in the area, especially not Southern States.
If you're interested in talking to other local 350Z owners, Packloyal, PM me.
Old Jan 16, 2004 | 06:04 AM
ldp118's Avatar
ldp118
so what happens if you get an 04 z number 52612 in assembly line?
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
