car shutting off randomly
Old Oct 28, 2012 | 11:20 AM
ny350zat's Avatar
ny350zat
Default car shutting off randomly
hey guys i was at a traffic light today and my car randomly shut off...2006 350z AT put it back in parking and turned it back on and everything seemed normal...any outputs? thanks in advance
Old Oct 28, 2012 | 12:20 PM
JCITY's Avatar
JCITY
Any CEL codes showing?
Could be one of your cam position sensors is going out.
Thats a symtom.Also,if its harder to start.
If it does go out,you will get a CEL plus other warning lights
may light up on the dash.
Old Oct 28, 2012 | 03:50 PM
ny350zat's Avatar
ny350zat
Nope no cel light nor any other lights, car restarted just fine and no wierd noises, the car is mind so its wierd
Old Oct 28, 2012 | 04:06 PM
ny350zat's Avatar
ny350zat
Mint*
Old Oct 28, 2012 | 04:49 PM
JCITY's Avatar
JCITY
Cool
I'd check the cam position sensors..thats usually how one starts going bad.
You might get another--engine turns off at idle, a week from now.Better
safe than sorry to get them checked.The car will still run,but poorly.Your mpg may drop.
If it is a cam sensor,and you replace,your car will seem like it
just added more hp.The sensors can become weak,have occaisional
blips.Very hard to notice.
Has your av mpg dropped?
Old Oct 28, 2012 | 06:06 PM
b18ccivics's Avatar
b18ccivics
If no dash lights came on, not even the battery light i would say it is the ignition switch. your car actually shut off.
Old Oct 28, 2012 | 07:28 PM
GLRacing's Avatar
GLRacing
Ignition.
Old Oct 31, 2012 | 09:25 AM
ny350zat's Avatar
ny350zat
My car shut off again today and my mpg r really low now (8-9 mpg)
Old Nov 1, 2012 | 03:34 PM
Spike100's Avatar
Spike100
You may have a loose line connection to your fuel tank. That causes leaking and explains the very poor mpg you report. It also allows air to enter the fuel line resulting in a vapor lock and engine shutdown (something you also report).
I think you should resolve this ASAP since it might be very dangerous.
--Spike
Old Nov 2, 2012 | 07:06 AM
ny350zat's Avatar
ny350zat
Well today my car officially ran out of gas! Thanks hurricane sandy but w.e I dnt think its the fuel lines since the mpg are affected not the overall gas tank, ill take it to service as soon as everything goes back to normal here in long island
Old Nov 2, 2012 | 03:58 PM
Spike100's Avatar
Spike100
Poor mpg is an indication of fuel loss.
You ran out of gasoline in your car today because you have a leak somewhere in your fuel system.
--Spike
etkms
Jun 19, 2022 06:30 PM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
AbyteZero
Sep 22, 2015 09:17 AM
AP350z223
Sep 8, 2015 04:38 PM
