Noises from the Right Front Tire
Old Nov 2, 2012 | 04:59 PM
LJF's Avatar
LJF
Exclamation Noises from the Right Front Tire
hey guys,
I currently have a huge problem, When i turn my steering wheel to the left, a clunking noise comes out of the right front tire. And when i turn my steering wheel to the right, a different grinding/whining sound happens. Since all i know is trucks im trying to figure this out, but stumped and its starting to nickle and dime me.
I seen on here that if you push your tire and it wobbles, its your center hub assembly, well i did that and neither side budged, so thats good, but afterthat i looked at my new upper control arm that i installed, and i noticed that the rubber boot has been worn away.
Would anybody know what caused my brand new boot to wear like this? Would off the top of their head know what the problem would be? i just want my car to be quite again, with out the fear of dying.
Thank you in advance.
Old Nov 2, 2012 | 05:33 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Is your car lowered at all? Factory suspension?
Old Nov 2, 2012 | 06:40 PM
LJF's Avatar
LJF
all factory as far as i know of. 350z enthusiast rolling on stock 17's
Old Nov 3, 2012 | 08:29 AM
Gunsmoke's Avatar
Gunsmoke
Check your inner fender liners for the grinding/whirring. Just an Idea.
As far as the clunk, tie rods, ball joints and end links. Wheel bearings usually whine and roar unless they are getting a lot of play then you get all of the above.
Old Nov 3, 2012 | 06:41 PM
LJF's Avatar
LJF
yeah on the way home, the upper arm pushed itself up into the wheel well. ill have to play dr tomorrow.
Ill check the items you have listed. Thank you.
Old Nov 3, 2012 | 09:19 PM
TheWoo's Avatar
TheWoo
Also, pay special attention to the bushing at the location where your lower control arm is bolted to the front member. I had a clunk when turning and it turned out that the bushing had failed, and allowed the control arm to move along that bolt. Research showed that it was a common problem for our cars after 80k or so miles.
This matter is covered in another thread, with excellent pictures of the problem I had: https://my350z.com/forum/brakes-and-...translink.html
Hopefully your problem is something minor!
Old Nov 4, 2012 | 09:04 AM
LJF's Avatar
LJF
well i really dont know whats going on with it, my upper arm still goes inside of the wheel well. Could my strut be blown?
Obadabot
Jun 18, 2023 11:31 PM
