Low Pressure and knocking!!!
Old Nov 14, 2012 | 10:53 PM
Rafal_Z33's Avatar
Rafal_Z33
Question Low Pressure and knocking!!!
I have an 05 350Z performance. I went out for a cruise and then i suddenly heard some knocking. I got out of the car and it was loud. I checked the oil and it was smoking. Also, I had to change out my oil a couple days ago even though i still hav about 800 miles left. I poured some oil in that i had in my trunk, and the knocking got quieter. This has been happening for a while wenever i get to my oil change date or a couple days past it. but wen i change it out it stops knocking. Does anyone know wat could possibly be the cause????
Old Nov 15, 2012 | 08:32 AM
JohnG202's Avatar
JohnG202
When you add oil does the noise go completely away or just quieter?
What oil are you using? Could be too heavy especially in the colder weather.
How low is your oil level when the knocking starts? If your levels are ok then something could be preventing oil getting to the lifters or your lifters are bad. A bad oil pump could also be the issue.
I'm sure someone on here knows way more than I do but it's a starting point.
Old Nov 15, 2012 | 09:17 AM
0jiggy0's Avatar
0jiggy0
How low is the pressure and how often and how much oil are you adding.
Old Nov 15, 2012 | 12:25 PM
Rafal_Z33's Avatar
Rafal_Z33
well wenever i do an oil change im missing about a quart
Old Nov 15, 2012 | 12:26 PM
Rafal_Z33's Avatar
Rafal_Z33
The noise goes away completely. but this month ive been hauling a** so its louder, but again i hav less oil than usual
Old Nov 15, 2012 | 12:49 PM
dubbingt's Avatar
dubbingt
Your engine is burning oil over time. Its somewhat common with the VQ. You get the noise when your engine has burned some off and it doesn't have enough to properly lubricate everything. From now on, check oil levels every couple of weeks and top it off.
Old Nov 15, 2012 | 04:43 PM
Rafal_Z33's Avatar
Rafal_Z33
Is this anything serious i should worry about?
Old Nov 15, 2012 | 05:15 PM
0jiggy0's Avatar
0jiggy0
Are you serious?
Your engine is burning oil, running low, then making noise. Wtf, keep the oil full, and decide when you want rebuild the engine.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
