2nd gear problem, please help
Old Nov 29, 2012 | 07:21 AM
Jah70's Avatar
Jah70
Default 2nd gear problem, please help
Hey guys i've had my 2003 enthusiast since march of this year and no problems until a few months back I started to notice that sometimes it was hard to get into 2nd gear. I always made sure I fully depressed the clutch and this never happened with any other gears that I shifted into. Then yesterday I was going out for a little run and went from first to 2nd I felt even more resistence to get into 2nd and I felt the gears grinding a bit. In a panic I went into 3rd and avoided shifting into 2nd the whole way home in fear that I might cause any damage. Am I overreacting or is this normal???? It doesn't happen that often, sometimes if it's a bit chilly outside it's hard to get into 2nd and with a bit of driving around it feels smooth like butter getting into 2nd when it's fully warmed up. Can anyone help me out to why this is happening? I haven't been sleeping well because of this problem.
Old Nov 29, 2012 | 07:46 AM
1LightBrick's Avatar
1LightBrick
03s are notorious for transmission problems. I nicked my 3rd gear sychro and had it replaced (under warranty). It would make a grinind sound when i shifted too quickly into 3rd. Even after i replaced it, it happened again and now i just drive with it.
I've found that if your having a little trouble getting a gear in, blip the throttle.
Old Nov 30, 2012 | 03:29 PM
Jah70's Avatar
Jah70
So I would eventually have to replace the syncros, or I can just live with it? There isn't any long term repercussions like my second gear going missing from being worn out over time if i just leave it?
Old Nov 30, 2012 | 03:46 PM
enZus's Avatar
enZus
Most just upgrade to cd009 trans to not have to worry about it again. As lightbrick said the older ones are notorious for problems
Old Dec 2, 2012 | 03:09 PM
PeterPotatoes's Avatar
PeterPotatoes
I have a 08 and it clunks going into 2nd if I shift too fast... or too slow. I tried adjusting the shifter plate but that didnt do anything. It seems if I put a certain amount of pressure it won't clunk. I've read this is normal as long as you dont hear grinding...
If I race it, smooth as butter.
Old Dec 3, 2012 | 12:28 PM
Jah70's Avatar
Jah70
Yeah I forgot to mention that part. When I really rev it out and start driving fast it's smooth, but when I drive normally i feel getting into 2nd gear is hard. Design flaw? Or is nissan trying to tell me that I should drive fast all the time?
Old Dec 3, 2012 | 12:40 PM
1LightBrick
You can live with it, definitely not worth the trouble of replacing a sychro. I did it and it happened again.
Save up and swap to CD009: thats common practice in these parts and theyre not as expensive as you'd think. ($600 seems to be what i find, im sure other people have found many others)
Just learn where it doesnt grind and shift there. You'll be fine. The car will be fine.
Old Dec 3, 2012 | 07:31 PM
Spike100's Avatar
Spike100
Hi... You are describing a problem that many 2003 owners experienced; to the point that Nissan began replacing the transmissions in 2003 350z’s.
I had my transmission replaced, and the new transmission was SO much better. It was like driving a different car.
--Spike
Old Dec 5, 2012 | 03:12 PM
PeterPotatoes
Yeah, it's just how it is. Since I have the new style trans there is no point in doing a swap until it actually start grinding all the time. I've only have mine grind twice, its cluncked a billion times though. I dont think damage is necessarily happing when it cluncks it's just how the trans is designed... but that's a total guess.
Uriyo_
Sep 8, 2021 08:46 AM
