MOTUL in the Drivetrain!
Old Feb 18, 2013 | 05:39 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Originally Posted by JDMStanced
Going into gears are really hard now with the motul.. especially first and second lol.
I should try amsoil next time..
With the JWT clutch and flywheel installation, it's REALLY hard to press in the clutch pedal... I mean REALLy hard lol..scared to press in the pedal But there's like no chattering at idle though
Sounds like you are having other issues, If it is harder in 1st and 2nd you have a release issue with the clutch itself or a hydraulic problem not allowing the clutch to completely release. Fluid won't cause hard shift issues normally and if it is a little thicker fluid it will only do it cold.
Old Mar 14, 2013 | 12:11 AM
tcode's Avatar
tcode
I finally did JWT clutch kit install and oil change in gearbox and diff. After bleeding out the system, I can't feel any difference in pressing the clutch pedal before and after, it might be even softer than it was with stock clutch kit.
Shifts are much smoother now, but that happen after gear stick alignment, mine was just a mm or less off, but it made a huge difference! You should check yours.
No gearbox chattering at all, although I have slightly higher idle (750 rpm) and I really take some time to smooth AFR around idle, so there are almost zero engine vibrations/shaking.
It revs much easier now
Old Mar 14, 2013 | 12:19 AM
JDMStanced's Avatar
JDMStanced
nice nice ! i love mine too. It will chatter more once you break it in.
my pedal was stiff as he** when i got it first installed. Now it got little bit softer but still stiffer than the stock.
How do you go about doing the gear stick alignment?
Old Mar 14, 2013 | 12:23 AM
tcode's Avatar
tcode
Here's a DIY, it's very simple to do.
Sunset350ZR
Nov 15, 2015 05:45 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
JonathanG35
Nov 26, 2003 01:18 PM
r34 racer
Aug 4, 2003 08:45 PM
