Can someone post a pic of the rear crankcase vent tube on rocker cover?
Old Dec 18, 2012 | 08:00 AM
ericjackson's Avatar
ericjackson
Default Can someone post a pic of the rear crankcase vent tube on rocker cover?
On my 03, i replaced the engine and was taking out the cam sensor last night on the LH (driver) side and noticed, i did not have a tube on the 'exit' for the crankcase ventilation on the rocker cover right above it. I looked at the manual and it says there should be a tube going to the 'air duct?' I do not see anything not hooked up or hanging. not sure where i would have missed it and usually i do not pull those tubes off if they are connected to the car. Can someone provide a picture for reference or at least describe where that is supposed to be connected.
thanks
Old Dec 18, 2012 | 08:03 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I have mine if you need it.
It is a big ugly shaped tube. Connects to the stock Z tube. There is a port on the bottom of the stock Z tube.
Old Dec 18, 2012 | 08:23 AM
ericjackson
interesting.... could this cause idle problems if it is removed? i wonder if thats my problem
Old Dec 18, 2012 | 01:43 PM
bmccann101's Avatar
bmccann101
id imagine so. Its a fairly necessary part, however ive not run w out one, surely someone will post in.
Are you meaning deleted and valve case sealed, or is it an open leak on the intake tube and the case?
Thats certainly not good.
Old Dec 18, 2012 | 01:45 PM
ericjackson
yeah its just open. i wondered why everything was so loud, but the car hasnt ran in a year so i could not remember. im sure the tube is somewhere in my garage, im going to see if it fixes my problem
ive only driven it a mile or two since its been back together
Old Dec 18, 2012 | 05:22 PM
ericjackson
well i put this back on and it ran great... until i threw the p0021 code again and wouldnt hold the idle. i guess that its really out
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
