Cooling Fan Relay, where is it & possible culprit?
A couple days ago, I noticed that my radiator cooling fans were coming on and would not turn off until I turned my car off. It has never done this before and I really don't remember the fans ever really kicking on and I live in Florida... Temp gauge is reading normal and I feel like the relay has gone bad or at least that's my hope of avoiding a much bigger and much more costly issue....
Can someone tell me where the cooling fan relay is?? Also, do you think this could be my problem or should I be looking at something else?
Thanks,
Chris
Thanks,
Chris
It may be be the relay. Look in your owners manual ithe relay should be in the fuse block. The mAnual should pinpoint where the the relay is for the fans. U can switch it with another relay to see if it changes anything just make sure the one ur switching with isn't important like a ECM relay.hope this helps.. Keep us updated.
