coolant coming out of exhaust
Old Jan 15, 2013 | 06:44 PM
jshoemate's Avatar
jshoemate
Default coolant coming out of exhaust
I tried a quick search but didn't see anything, but I was losing a small amount of coolant and started looking for leaks then two days later it overheated on me at my parents house. I couldn't find where it was coming from but on my other Z's everything I had an issue with coolant leaks it was the thermostat so I put a new one in and started gettin the air out and my friend noticed it blowin out the exhaust after it warmed up. I'm guessing the head gasket but I didn't want to tear into it until I had more opinions. Anyone know of somethin less of a pain it could be that I could check out?
Old Jan 15, 2013 | 09:43 PM
dcains's Avatar
dcains
Head gasket, cracked head, cracked block - pick your poison. Hopefully, it's just a head gasket.
Old Jan 16, 2013 | 03:15 AM
04.350z's Avatar
04.350z
Do a compression test that will help send you in the right direction if it were engine related. If you have a leak like you previous z pressure test the coolant system and it will push coolant out where your leak is
Old Jan 16, 2013 | 11:02 AM
jshoemate's Avatar
jshoemate
I'll try that out when I can get back to it, I just really hope it ain't the head gasket or it being cracked or something but it looks like it is.
Old Jan 16, 2013 | 11:59 AM
Chris Grove's Avatar
Chris Grove
Definately sounds like a head gasket. When mine was spitting some coolant out of the exhaust, that was the problem. I replaced the head gasket and had a pressure test on the block done with no issues found with the block. Hope its just the head gasket for you. They are not to bad to replace.
Old Jan 16, 2013 | 01:13 PM
jshoemate's Avatar
jshoemate
OK, guess I'll give it a shot. How hard for someone who's never been that deep before?
Old Jan 16, 2013 | 01:17 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I would strongly recommend you go to a shop if it's head gasket
Old Jan 16, 2013 | 01:24 PM
jshoemate's Avatar
jshoemate
I don't have the money now, I'm still payin for it and goin thru a divorce and lost my job. My life has actually turned into a country song lol
Old Jan 16, 2013 | 02:05 PM
Spike100's Avatar
Spike100
I will guess the head gasket. You should have this repaired ASAP since it will result in additional damage to your engine. --Spike
Old Jan 16, 2013 | 03:38 PM
jshoemate's Avatar
jshoemate
Yea, I haven't driven it since it overheated. It's been parked at my mom's for around a week.
Old Jan 16, 2013 | 04:25 PM
taywan's Avatar
taywan
Dang, thats a lot going on. Sorry to hear.....
Old Jan 16, 2013 | 05:07 PM
Chris Grove
If you havent been that far into an engine before it might be a bit of a PITA. If you are mechanically inclined and have the tools and required parts such as new head gasket and since your taking everything off might as well replace all the gaskets up top. You can get a kit from nissan or Autozone. Also since you have not done a head gasket before I hight recommend a repair manual, you can get a Haynes at Autozone, they are not the greatest but will work. Read over the process before attempting and make sure you feel confident that you can complete the job. Dont want to start a job and leave it half done. If you do attempt, remember to keep all bolts and parts organized and labeled. Organization is key.
Old Jan 16, 2013 | 05:21 PM
oldschool350z's Avatar
oldschool350z
Damn head gaskets can be such a pain. Trust me I've owned a couple Subarus.
i never knew our engines had issues with them? Could it be just isolated problem or luck of the draw?
My guess it could've been an existing issue from the previous owner if you bought the car recently.
Old Jan 16, 2013 | 05:34 PM
2004Black350z
Exhaust Whore
Seems this guy has terrible luck. Sorry guy. Iv had my life as low if not lower and I'm on top of the world. Stay positive buddy.
Old Jan 17, 2013 | 09:58 AM
ehaalandtluk's Avatar
ehaalandtluk
Guys, just a question. I've done everything short of removing heads in my engine bay. If I would like to mess with my heads (send them out to get ported/cams/etc) do I need to remove the engine or can I do it in place?
Thank you.
Old Jan 17, 2013 | 11:13 AM
str8dum1's Avatar
str8dum1
you gotta take the timing cover off.
So short answer is no, you cannot do it in your car.
Old Jan 17, 2013 | 01:00 PM
ehaalandtluk
Darn, lol. There goes my winter project.
Old Jan 23, 2013 | 08:49 PM
jshoemate's Avatar
jshoemate
It'll be aight, I still got a place to stay and food and beer lol. But I did get confused today. I got back out to it today and did a compression test and they were all good. All of them around 135. But my buddy told me that he saw water spraying out Pretty good from the exhaust. I'm kinda confused now, could I have good compression and still a bad head gasket? Thanks for all the help guys.
Old Jan 25, 2013 | 03:21 PM
Spike100's Avatar
Spike100
^^ Yes. The compression tests individual cylinders. The head gasket seals the cover over the top part of your engine. --Spike
Old Jan 25, 2013 | 03:36 PM
jshoemate's Avatar
jshoemate
OK, just wanted to double check before I really tore into it. Thanks.
