car won't start after putting in gas
no I did not put in diesel gas.. that out of the way my car starts and shuts off.. tried giving it some gas after it starts but the rpm doesn't even budge and dies again.. any ideas? stuck at gas station 45 miles away from home! helpppp
did this literally start RIGHT after you put gas??
were you running on empty? I have heard if you run the car /hardish/ it can cause strain on the fuel pump and burn it (since its cooled by gas)
One thing u can do is spray some carb cleaner or starting spray/ether or even parts cleaner straight to the throttle body area by take the intake tube off and immediately try starting the vehicle. Or u can spray where the air filter intake tube is just avoid spraying the mass air flow sensor by spraying past it hopefully the spray u buy has a straw. Spray for bought 5 seconds in either of those areas. It may get it going. Try a few times if it keeps shutting down. After 2-3 attempts u know u may have a fuel issue pump or ecu. Wanna have it towed by that time. Hope this helps and it's not too late let us know what the cause was.
