Power Loss driving me crazy
Old Feb 15, 2013 | 10:52 AM
lungta's Avatar
lungta
Ok I'll try that but what does the yaw sensor has to do with the cam sensors ?
Old Feb 15, 2013 | 11:25 AM
Tracktimeplz's Avatar
Tracktimeplz
Nothing, but thats the point. It could be VDC spazzing out due to some anomaly, by pulling that yaw sensor, you will know 100% that VDC isnt causing the problem. Just process of elimination, helping you get closer to seeing if its the Cam sensor.
Old Feb 20, 2013 | 01:35 PM
lungta's Avatar
lungta
Ok, haven't gotten to removing the yaw sensor yet but is there any chance it could be a bad o2 sensor ?
I've replaced the cam sensor with OEM Nissan parts so I'm guessing the odds for them to be bad are slim.
Is there a way to test the Mass air flow sensor and throttle body before I go ahead and shell out some more dough on these ???
Old Feb 20, 2013 | 01:53 PM
Tracktimeplz
You should be getting CEL if any of those are the problem, so unless your ECU isnt functioning properly, those items probably arent the culprit.
Do you have an OBD2 Adapter that you can plug in, and do some logging?
Old Feb 20, 2013 | 01:57 PM
lungta's Avatar
lungta
I don't have a CEL light.
Yes I have an OBD2 Adapter but they are no error codes.
Old Feb 20, 2013 | 02:26 PM
Tracktimeplz
Yes, but can you set up a logging session? What kind of OBD2 Scanner do you use? One with a phone app, or one of the old crappy stand-alone units
Old Feb 20, 2013 | 03:27 PM
zakmartin's Avatar
zakmartin
If it's an intermittent loss, I'd be looking at the fuel pump first.
I knew a guy who had a car that kept bogging down when he'd go fast, then he'd stop and the car would run fine. Turned out to be a bunch of twigs and army men that his kid dropped into the gas tank. I know that's not likely, but you could have a pump that's starting to quit on you.
Old Feb 21, 2013 | 01:38 PM
lungta's Avatar
lungta
It's a PLX Kiwi 2 that I use with DashCommand on my iPad. Yes I think you can setup a logging session.
Not sure if its the fuel pump. I think it would completely shut down on you instead of a half second cutoff
Old Feb 24, 2013 | 04:22 AM
lungta's Avatar
lungta
A little update. On top of the quick power loss, the car will randomly stalls while idling now. It cranks right back up afterwards but still a pita. Does this lead to any more suggestions from you guys ?
Old Feb 24, 2013 | 06:04 AM
350zsunshinefl's Avatar
350zsunshinefl
Stalling at idle now makes it less likely a VDC problem, though it could still be a sensor malfunctioning.
It seems like you knocked out most of the common issues, I am guessing an electrical problem, check all your grounds. I've noticed you have a UR crank pulley, a while ago I had a friend who had similar problems (without stalling though) and it turned out to be one of his aftermarket pulleys,
taking it to nissan not an option? or find a nissan mechanic of craiglist
Old Feb 24, 2013 | 10:49 AM
lungta's Avatar
lungta
Car is going to a garage this week. I'll check for the grounds. What other sensors could it be ? Could it be the injectors or coil pack ?
Old Feb 25, 2013 | 11:59 AM
Tracktimeplz
ah HA! gives me an idea...
the alternator belt may be slipping. A voltage log would confirm this
Old Feb 25, 2013 | 12:32 PM
lungta's Avatar
lungta
I will check it tomorrow but if the alternator belt was slipping wouldn't I hear some squealing from the belt ? And wouldn't be difficult to start the car ?
Old Feb 25, 2013 | 12:51 PM
Tracktimeplz
Not necessarily, and no.
The alternator charges the battery, while the car is running, but doesnt affect startup. As long as its running enough to top the battery off, you would be able to fire up each time.
if you cant log with your app, just get someone to slowly increase revs while you check the voltage with a multimeter. Having said that, id still like to see the timing log, if possible
Old Feb 25, 2013 | 02:00 PM
lungta's Avatar
lungta
Where should i check the voltage ? Check your pm
Old Feb 25, 2013 | 03:01 PM
Tracktimeplz
PM Replied
Old Feb 26, 2013 | 05:55 AM
lungta's Avatar
lungta
Tracktimesplz - check your pm and mail.
I dropped the car this morning to my mechanic's shop. We'll see what we says
Old Mar 1, 2013 | 04:51 AM
  #38
lungta's Avatar
lungta
Guys, problem fixed. Turns out, the old shop who replaced the crank sensor zip tied the harness so tight and didn't leave any extra play in the harness.The vibration of the engine block was enough to pull on the connector and make a bad connection. What a hassle ! At least I have new cam and knock sensors, and my old ones as spare...
Old Mar 1, 2013 | 09:03 AM
  #39
Tracktimeplz
wow.... well glad its fixed, just in time for the driving season
