Plz help! new door/relearn
Old Jan 29, 2013 | 06:30 AM
shine-EZ's Avatar
shine-EZ
Default Plz help! new door/relearn
Hey guys, 2003 gt
I got into a bad accident but completely repaired my z
After installing my new drivers door I could not relearn the window motor.
As of right now:
No auto up/down
Shut door, window drops n repeats as i shut it over and over
I know the relearn procedure BUT, this doors window motor does not have a reset button!! Also why no auto up?
Ive reset my old motors a few times so i know the procedure..
Can someone help me out!???
Old Jan 29, 2013 | 09:22 AM
02s2000's Avatar
02s2000
I recently installed a drivers side window door motor with the same problem. I have installed other window motors and was able to reset them. Anyway I have the same problem. It continues to lower about two inches every time I open and close the door til is is all the way down. The window goes up and down fine but just continues to lower itself.
I took a look at the motor the other day and it seems the reset button assembly has separated from the motor and is sorta flopping in the breeze. I think the only cure is a new window motor.
I have a feeling your reset switch is behind the door panel hanging to low to see it through the small reset window of the door panel.
Old Jan 29, 2013 | 01:12 PM
shine-EZ's Avatar
shine-EZ
So u think, If i just replace the motor with my other one it will work?
I can do that i just thought there was another way of doing this
Also, will it fix my auto up/down feature?
Ive replaced the motors a few times and never have seen this style of motor
Thanks
Travis
Old Jan 29, 2013 | 02:35 PM
shine-EZ's Avatar
shine-EZ
Its weird cuz when i look thru the pilot window there is no spot for the reset button .. Its just a metal casing for the motor..
i need someones input
I can swap motors i guess i just didnt want to if theres nother way to fix it. Also im concerned about my auto up/down feature.
Old Jan 30, 2013 | 04:11 PM
shine-EZ's Avatar
shine-EZ
Nobody has input? I thought this was a pretty common issue we have...
Old Jan 30, 2013 | 09:37 PM
shine-EZ's Avatar
shine-EZ
Stripped my old door panel, removed regulator woth motor attached, glass, and handle with my key cylinder.
Waiting on a nice day to install it. Shes cold as cold can be in canada!
bugz
Apr 9, 2004 03:11 PM
dchi_t
Aug 24, 2003 08:53 AM
bugz
Jun 21, 2003 11:51 PM
Zb4-18
Sep 8, 2002 07:04 AM
