If you need any welding tips or advice...
Old Mar 2, 2013 | 09:44 AM
Engloid's Avatar
Engloid
Default If you need any welding tips or advice...
I've been welding for over 20 yrs, and had a lot of experiences and certifications. If you have something you want to weld and don't know how to do it, what gas to use, process, or anything, I will try to help. If you just like welding and are trying to get better at it, post up pictures of your work and I will give tips.
BTW, if there is a better suited category for this, please move the post.
Old Mar 2, 2013 | 09:57 AM
faiz23's Avatar
faiz23
FEZZZZZZ
Old Mar 2, 2013 | 10:43 AM
mr. sparco's Avatar
mr. sparco
I bought a cheap arc welder, splattered some boogers, and gave up shortly after. I think I need something better. Thanks for making a 'help' thread as this would benefit those getting into the skill.
Old Mar 2, 2013 | 10:49 AM
Engloid's Avatar
Engloid
I will see if I can find some pictures of my work. I used to have them all over the internet, but I guess they were hosted on my old comcast server, so they aren't available anymore.
And now, I work in a govt plant where we aren't even allowed to have our cellphones...so can't take pictures of the work I do there or the "men in black" will come to get me.
Old Mar 2, 2013 | 11:15 AM
ducky's Avatar
ducky
ah....it is you I posted in your other thread. Gentlemen this guy is legit...he's a master Jedi when it comes to this. I remember following his posts/threads years ago about fabbing. Truly an honor to have you aboard...
Old Mar 2, 2013 | 11:29 AM
Engloid's Avatar
Engloid
Thanks for the compliment. Where was it you saw my posts before? I used to do a lot of posting on z31.com back when I had 300zx's.
Old Mar 2, 2013 | 11:40 AM
BornSlippyZ's Avatar
BornSlippyZ
When my kids are in school full time, I am going to learn how to weld. I had a machinist at my old job try and teach me but we never had time beyond the first time.
Old Mar 2, 2013 | 12:22 PM
ducky's Avatar
ducky
Actually it was a non-nissan site. Saw your work on pirate4x4, Honda and homemade turbo, also your website when it was active....
Old Mar 2, 2013 | 01:31 PM
TuckerE36's Avatar
TuckerE36
How much exp do you have with TIG? I have pretty good exp with a stick and MIG but am learning ways to improve using a TIG welder, any tips?. It's just so much more craftier, I enjoy it the most out of the three.
Old Mar 2, 2013 | 06:09 PM
Engloid's Avatar
Engloid
I've got quite a bit of TIG experience. I started back about 1987. I did find a few pictures of some of my work. Most of it's a few years old, at least.
In order:
1) DC aluminum TIG on a wave guide (microwave vacuum oven setup)
2) Stainless steel, 308, 2" pipe
3) Same as 2
4) This was some piping I put into a papermill, if I remember right, it was 8 and 10 inch.
5) Same as 4
6) A vacuum oven, about 3ft diameter, vacuum chamber type of stuff
7) This was a nitrogen station that I built at a steel mill.
8) This was also at the steel mill. I had to build new piping to tie into the existing equipment
9) Another of the back side of the nitrogen station
10) DC aluminum TIG
Attached Thumbnails If you need any welding tips or advice...-021909_1142-00-.jpg   If you need any welding tips or advice...-032709_1519-00-.jpg   If you need any welding tips or advice...-032709_1521-00-.jpg   If you need any welding tips or advice...-051600_1547-00-.jpg   If you need any welding tips or advice...-051600_1549-00-.jpg
If you need any welding tips or advice...-051900_1952-00-.jpg   If you need any welding tips or advice...-071709_0725-00-.jpg   If you need any welding tips or advice...-071709_0726-00-.jpg   If you need any welding tips or advice...-071709_0729-00-.jpg   If you need any welding tips or advice...-080709_1206-01-.jpg
Old Mar 2, 2013 | 06:11 PM
Engloid's Avatar
Engloid
Here's a few more...
in order:
1) AC aluminum TIG
2) This was a cyclone that helped remove sand from saltwater. It was made of 254SMO material, welded with Hastelloy.
3) Copper-Nickel (95/5) TIG welded
4) Full penetration root pass inside a 6in carbon steel pipe, TIG welded.
5) Part of an X-pipe I made years ago
6) This bmp file, for some reason won't show as thumbnail. This is a 254SMO 2" socket weld fitting. I wasn't quite done with it when the picture was taken. I still put one more stringer around the top.
Attached Thumbnails If you need any welding tips or advice...-080709_1206-01-.jpg   If you need any welding tips or advice...-cyclone5.jpg.jpg   If you need any welding tips or advice...-dscf0012.jpg   If you need any welding tips or advice...-dscf0068.jpg   If you need any welding tips or advice...-dscf0292.jpg
File Type: bmp
Old Mar 2, 2013 | 06:40 PM
ducky's Avatar
ducky
never ceases to amaze me when I see your work. Your welds look better than a robot's.
great stuff sir!!! I'm sure we will learn a lot from you.
Old Mar 2, 2013 | 09:21 PM
bealljk's Avatar
bealljk
Step 1. buy a welder
Step 2. buy scrap metal
Step 3. learn…
I got a question for the jedi master…
Looking to weld a few aluminum AN fittings to a steel pipe…best way?…I cannot do this, I have a miller suitcase w/a roll of flux core…but I'm assuming it's possible and 'about' what should I expect to pay someone to do this?
Old Mar 3, 2013 | 08:54 AM
Engloid's Avatar
Engloid
Step 3. learn…
It can be done with MIG, but TIG is going to be best for it, since it's just a couple of them. If you were doing these for a production company, I'd look at perfecting the MIG on it, to make them look good and still be quick and solid. However, for a couple of them, I'd reccomend TIG.
To weld a couple of them on a pipe, will probably take about an hr by the time you figure setup, setting machine, cleaning, and cleanup. How much you will pay will vary greatly...by location, and skill of the welder. I mean, if you knew 100% they would be done right and look great, you probably woudn't have a problem paying $100 to have it done, would you? Odds are, it won't be that much. Therefore, I'd just be very selective as to who you have do it. Make sure you see some of their other work, expecially some AC aluminum. My best guess would be that you will wind up paying about $40-75. Anything under $40 and I would have to wonder why it's so cheap. You know the old "too good to be true" thing. Perhaps the guy isn't worth crap and he's not really worth that.
Let me know how it turns out.
Old Mar 3, 2013 | 12:10 PM
BornSlippyZ
I used to work in the hydraulic/motion control industry and I recognize great work when I see it!
Old Mar 3, 2013 | 01:26 PM
b18ccivics's Avatar
b18ccivics
glad to see you are on here, I have been recently trying to weld some aluminum with no luck. I keep getting contamination. Going to change tanks again to see if that helps. Changed everything else twice with no luck.
Old Mar 3, 2013 | 01:46 PM
Engloid's Avatar
Engloid
Good to see some Honda guys get better cars once they can afford them. A true sign of intelligence.
The funny thing...I just got my 350z almost 2 months ago. Guys at work think I'm some kind of rich guy now...but many of them drive trucks and Hondas that cost them more than my Z cost me.
Contamination can be several things. Usually, it's a problem with gas coverage. Most often, beginners will tend to "long arc" at times, pulling away from the weld, not keeping proper arc length, which can result in contamination.
It can also be caused b dirty base or filler metal, contamination inside the cup or gas lens (usually indicated by smoke coming out of them when hot).
The lease common cause is dirty gas.
You are using 100% argon, or 75% argon/25% helium, correct?
Old Mar 3, 2013 | 02:11 PM
Engloid's Avatar
Engloid
Thanks. I've done it so long, it gets a bit boring at times, but I'm at a point now where it's all about the money to me. I invest money best I can, because I know welding won't ever make me a rich guy...but wise investments may.
Old Mar 3, 2013 | 05:42 PM
TuckerE36's Avatar
TuckerE36
Dude those were some clean beads, good work!
Old Mar 14, 2013 | 05:29 PM
Engloid's Avatar
Engloid
Thanks. I wish I could take pics of recebt welds at work....doing three inch carbon steel...all TIG.
