Wreck #2
Old Mar 12, 2013 | 02:53 PM
0d5r3i5f0tZ's Avatar
0d5r3i5f0tZ
Default Wreck #2
Posted this on the 350z group on Facebook as well.
In need of some advice, seem to be in over my head on this one.
Long story short, the z went over a 6 inch curb head on. I'd say 15 to 20 mph. Blew a rocker cover gasket putting cold motor under load when trying to pull her out.
Rocker cover gasket replaced, motor running strong. RIP front bumper, Bent front two rims, and steering/alignment out of wack (obvious given). What i don't understand is why the vdc and slip lights are still on. Even after changing the wheels and a half *** garage alignment. Can this even be caused by alignment issues? Did vdc get messed up with the car stalling in gear under load?
Idk I'm lost on this one and stuck using a phone for research.
Any help, thanks guys.
Old Mar 12, 2013 | 07:49 PM
gregom's Avatar
gregom
ABS sensors up front may be damaged or were knocked out of position. I'd check there first...
Old Mar 12, 2013 | 07:58 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Don't forget the wheel speed sensors on the rear diff as well. Curb hopping like that probably damaged the entire harness and could explain why the VDC and slip lights remain on.
gc350z03
Oct 28, 2016 05:00 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Martyg
Dec 10, 2003 04:36 PM
JimH
Mar 31, 2003 08:19 AM
zeroday
Mar 29, 2003 08:57 AM
