04' z, Service Engine + TCS + Slip lights all came on at same time
Old Mar 14, 2013 | 02:20 PM
RIKjustin's Avatar
RIKjustin
Default 04' z, Service Engine + TCS + Slip lights all came on at same time
I know this has been posted before about 5 years ago.
I cranked my Z a few weeks ago and haven't ran it in about 2 weeks prior to that. The crank kinda stuttered and then cranked with all the above lights coming on. I let it run for a little while and then drove it and didn't really notice anything out of the normal. I have been running the car almost every day for the last week and the service light stays on all the time now and every now and then the TCS + SLIP light would come on with some of the cranks being not normal.
I have done a little research and could possibly be a loose wire but haven't found a fix. Anyone know of a fix and what the possible issue is?
I am about to sell the car and would like to have the issue resolved as quickly and without paying an arm and a leg.
Thanks!
Old May 14, 2014 | 06:14 AM
bluebadge's Avatar
bluebadge
Did you ever figure this one out? I have exactly the same issue on my '04 zee please post a follow up! I need HELP!
Old May 14, 2014 | 06:19 AM
travlee's Avatar
travlee
Master
you know this post is over a year old right? mine did this when i was on a dyno... try driving it or resetting the ecu
Old May 14, 2014 | 07:44 AM
myfirstzcar's Avatar
myfirstzcar
A code reader would be a great place to start if the reset doesn't help.
Old May 14, 2014 | 07:46 AM
bluebadge's Avatar
bluebadge
I knew it was an older post, but at first I couldn't find anything on it. I've had some luck in the past asking for follow ups as members forget to update after an issue is solved. I think I found a better article on here about it though, sounds very much like a crankshaft position sensor or camshaft position sensor. May try your suggestion also though.
Cheers
BB
Old May 14, 2014 | 07:51 AM
travlee's Avatar
travlee
Master
Cheers
BB
my buddy had this happen, but not all his lights came on... sounds like your ecu is freaking out for some reason
Old May 14, 2014 | 12:26 PM
bluebadge's Avatar
bluebadge
Well I hooked it up to a diagnostic and it threw out a P0340 code, so first item to cross off my list will be the camshaft sensor bank 1. if that doesn't fix it I will move on to the next sensor and lastly the crankshaft sensor.
fingers crossed.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
