2007 350z hard start/idle is low/high, can't run.
Old Mar 28, 2013 | 05:12 AM
silvestri88's Avatar
silvestri88
Default 2007 350z hard start/idle is low/high, can't run.
My car has been having hard starts (on and off, always figured the batter was just old) for a while now. One day heading home from work my car nearly went into a stall. The car began to shake, the slip light came on, the throttle wasn't very responsive. I pulled over and attempted to start the car 10-15 minutes later and nothing. I figured maybe it was the cam shaft sensors, so I replaced the two (driver and passenger) in the rear of the engine towards the firewall (back of the engine nearing the inside of the car). Still no dice. The car has difficulty starting and once it does the idle is up/down. Usually takes a little gas to start it. Once running it seems as if it wants to die and the entire car begins to shake so I kill it before something more serious happens. Any ideas? Apparently autozone said there's 4 sensors. I think I see the other 2 (near the front of the engine), but I don't know how to get them out since when I unbolt the 10mm bolt it seems to be attached internally by wires. Any and all help would be greatly appreciated!
Old Mar 28, 2013 | 08:38 AM
BipJip's Avatar
BipJip
sound like a throttle position sensor. do you have any DTC codes??? or check engine lights?
Old Mar 28, 2013 | 09:09 AM
silvestri88
What's DTC? I've been having a check engine light on ever since I installed intakes/headers/HFC's/y-pipe/exhaust. I've just been ignoring it (I know, bad).
Old Mar 28, 2013 | 09:11 AM
silvestri88
If I could get it to autozone I could get them to put a code reader on it, but I can't. :/
Do you know where the throttle sensor is located on a 2007 (dual throttle body) Z?
Old Mar 28, 2013 | 10:01 AM
BipJip's Avatar
BipJip
A DTC = Diagnose Trouble Code. you can buy a cheep version of the scan tool from autozone around $40. your throttle position sensor is on the inner side of the throtle body. one side has the actuator motor and the other is the sensor.
Old Mar 28, 2013 | 12:02 PM
oldschool350z's Avatar
oldschool350z
I got a cheap scan tool from amazon for $20 and it works just like theirs.
Old Mar 28, 2013 | 04:50 PM
silvestri88
Could you please link me?
m_0g
Jun 3, 2021 10:05 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
bryanlam199
Sep 24, 2015 04:04 PM
Upstreammiami
Sep 17, 2015 02:45 AM
issyz
Sep 12, 2015 04:18 PM
