Trunk springs not allowing your hatch to open first try? Easy fix
Old Apr 2, 2013 | 12:48 PM
Cracka350's Avatar
Cracka350
thx for the fix. I hate that problem. I bought new struts but they dont help for the innitial release.
Old Apr 3, 2013 | 05:31 AM
350TX's Avatar
350TX
I agree, I replaced the struts for stronger units which are built to handle the additional load of a spoiler, which I don't have, and replacing the struts alone does not assist in the initial release, or pop of the hatch.
Either do this little quick fix or replace the springs.
Old Apr 11, 2013 | 08:37 PM
zJames's Avatar
zJames
you think if i added another nickel it would give my hatch enough pop to catch the struts and just open up? i have the z1 upgraded struts (medium grade) the hatch unlocks i just always have to give it a little push with my hand to open up
Old Apr 11, 2013 | 09:16 PM
mr. sparco's Avatar
mr. sparco
Tape a nickel on each side to find out before install.
Old Apr 12, 2013 | 02:20 PM
Spike100's Avatar
Spike100
OK… If your hatch won’t “pop” after installing new struts and springs, then it’s probably misaligned. When the hatch is not aligned properly, the release might not work since the pressure is angled instead of straight. This is not a common problem with the Z since the hatch design is nearly bulletproof. Owners having the problem are often unfortunate buyers of cars that have been in rear-end crashes that they did not see on the Carfax report.
If your hatch fails to “pop,” have your dealer evaluate the problem. A fix typically requires service from a reputable body shop familiar with the Z car.
--Spike
Originally Posted by SQuaLZ
I have the HP struts on my car, and had the UHP struts before that. They raise the trunk good, but I still have the issue with popping it. I even bought new rubber stoppers from Nissan and it didn't help at all, so I gave up lol.
Old Feb 21, 2014 | 04:58 PM
boss777's Avatar
boss777
Does any one knows where to get one? Am missing one.
Old Jan 17, 2022 | 11:53 AM
007swallow's Avatar
007swallow
Thats brilliant, thank you. Cost me 80p, took less than ten minutes and worked perfectly..
Uriyo_
Sep 8, 2021 08:46 AM
