Reverse Lights Won't Work
Old Apr 25, 2019 | 03:49 PM
bruthaboost's Avatar
bruthaboost
I know this is a necro bump, but wanted to confirm for anyone that happens to have this problem. It was indeed the fuse by the battery under the trim panels. It was fuse AT CONT.
Old May 5, 2019 | 10:16 PM
Jonuniv's Avatar
Jonuniv
Very useful, actually, also was AT CONT. In my case, I’ve blown it when checked the wire if it’s reverse or not.
Old Feb 12, 2026 | 08:17 PM
Despot018's Avatar
Despot018
Default Year 2026! 😂
Aight fellas! I lost reverse lights while I was trying to install my extra fancy EBay backup camera,replaced the reverse switch, I found that if you drop the transmission just 1 inch lower, there is waaaay more room for activities,and yes, 2 screwdriver method worked like a charm taking that connector off.
Howerver! That didn't fix my problem,for me it ended up being the NEUTRAL POSITION SWITCH which is in a similar location but on the passenger side.
So if some of you keep having the same issue,you may wanna take that sucker in consideration as well!
Hope it helps! 💪
Old Feb 17, 2026 | 04:05 PM
icer5160's Avatar
icer5160
@Despot018 I think it would help if you specified if you have a manual or automatic.
-Icer
Miguel Albanez
Oct 17, 2022 10:13 AM
bcoffee20
Nov 19, 2015 06:39 PM
Shane86
Sep 17, 2015 05:33 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
