The Dr Bonz Tire Swap TSB Tutorial
Old Jan 21, 2004 | 04:49 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Default The Dr Bonz Tire Swap TSB Tutorial
Several threads have been posted recently asking questions about the tire feathering issue and about the "tire swap" TSB (technical service bulletin). I have also been PM'ed a few times about this as well. Many moons ago I posted a demo on what the TSB involves. I used my trusty little Dodge Stealth TT model to show exactly how it's done so that people can understand it.
I thought I'd post this tutorial that (hopefully) explains the issue and the TSB so everyone (especially new owners) can understand it.
Here goes:
First of all, let me try to explain what feathering is. If you squat down facing your front driver's side tire after turning your steering wheel to the far left, we are concentrating on the innermost line of tread.
This pic will help:
Old Jan 21, 2004 | 04:52 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I heard it best decsribed by NSANY on Frenzy. He said it is like petting a cat's fur, first the "right" way and then against the grain so to speak.
Now, the TSB from Nissan is worded as such:
TSB: Ntb03006
IF YOU CONFIRM: An applied vehicle shows the following symptoms when braking moderately: • excessive tire "roar" or "growl" noise, mostly when braking at speeds below 30 mph. ACTIONS: Verify the incident noise as described above. • Check alignment. Adjust (if needed). • Rotate front tires from side to side, dismounting tires from wheels. See this bulletin for detail.
Old Jan 21, 2004 | 04:54 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
OK, now what exactly does that mean?
Allow me to demonstrate with my Dodge Stealth TT model.
I have marked the feathering with white out and the arrow depicts the rotational direction of the tire. The Z has "directional" tires that MUST rotate in this marked direction.
I have removed the wheel from the front drivers side of the car:
Old Jan 21, 2004 | 04:55 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
The tire is removed from the wheel:
Old Jan 21, 2004 | 04:56 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
The tire is put back on with the feathered part now on the OUTSIDE. Note as the car sits, if I put THIS wheel/tire combo on the drivers side again, the arrow is going in the WRONG direction.
Old Jan 21, 2004 | 04:57 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
BUT, when I put this wheel/tire combo on the PASSENGER SIDE of the car, it is rotating correctly!
Old Jan 21, 2004 | 04:58 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
There! I hope that helps. Let me know if you have any additions or corrections.
Old Jan 21, 2004 | 08:43 PM
goku's Avatar
goku
LOL
Old Jan 21, 2004 | 09:41 PM
LaoSiFu's Avatar
LaoSiFu
LOL
Old Jan 22, 2004 | 03:40 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
It isn't SUPPOSED to make you LOL!!
It's EDUCATIONAL!!!
Old Jan 22, 2004 | 05:18 AM
kitkos's Avatar
kitkos
Good post Binz,
We keep seeing these horror threads about feathering.
At 5k miles I, also, was a victim of feathering.
Nissan put on 2 brand new wheels and adjusted camber and toe.
I now have 17k miles and not one bit of feather.
After 12k miles I think I can say mine was fixed.
Old Jan 22, 2004 | 06:29 AM
Bertg's Avatar
Bertg
Nice post Doc!
Old Jan 23, 2004 | 05:01 AM
tbadiuk's Avatar
tbadiuk
Your Stealth has tire feathering??
Or was that just used for demo purposes?
Ted
Old Jan 23, 2004 | 10:27 AM
overZealous's Avatar
overZealous
Originally posted by kitkos
Good post Binz,
Just curious...How did Nissan adjust the camber exactly? I don't see any suspension mods on your list. Very nice car by the way.
Old Jan 23, 2004 | 08:16 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
No, the Stealth is fine. 12 years old and 108K and still running like a champ.
Oh BTW............BINZ?????
Old Jan 27, 2004 | 09:25 AM
lascala26's Avatar
lascala26
What does TSB: Ntb03006 (A) cover?
Old Jan 27, 2004 | 05:56 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I've seen people post about it but never saw a definitive answer. I think it's simply the same thing (the swap) but with the new alignment specs.
Old Jan 27, 2004 | 05:58 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
File Type: bmp
Old Jan 27, 2004 | 06:00 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Attached Thumbnails The Dr Bonz Tire Swap TSB Tutorial-new-tire-swap-tsb2.jpg
Old Jan 28, 2004 | 09:22 AM
only1's Avatar
only1
Are those the newest alignment specs available? Could I rint those out and take them to my dealer, cuz I dont think they have any idea.
