Need help, car wont crank, no codes,
Old May 1, 2013 | 04:17 PM
banga81's Avatar
banga81
Unhappy Need help, car wont crank, no codes,
03 350Z daily driver N/A
130K miles
- At the race track and car shutsoff while driving, (PDX event)
- tried to restart but wont even crank, just a single click.
- No error codes for crank and camshaft sensors.
- battery has good charge
- radio and all lights work so i assume altenator good.
- ground cable on battery had light corrosion, cleaned but same problem.
- removed battery for 36hrs to reset ECU, no change.
- fuel pump turns on when i turn the key.
PLEASE I NEDD HELP ASAP BEFORE TOWING TO DEALER.
THANKS
Old May 1, 2013 | 05:44 PM
dkmura's Avatar
dkmura
General & DIY Moderator
When you say the battery has "good charge" what do you mean? How old is it and what are the DC readings from your multimeter?
Old May 2, 2013 | 09:06 AM
banga81's Avatar
banga81
battery was tested with a crank output of 600...so thats more than sufficient to get to turn the starter over...
Old May 2, 2013 | 07:37 PM
dkmura's Avatar
dkmura
It's even money your problem is electrical in nature. I usually try to rule out the lowest link in that chain. That's why I asked how old your battery is. You need at least 12.5 volts DC to operate.
Recheck your ground and positive cables before you take it to the dealer. Let us know what happened.
Old May 9, 2013 | 05:41 AM
dkmura's Avatar
dkmura
So what's the story on this repair? What did it turn out to be?
Old Sep 29, 2013 | 04:22 PM
13ino13's Avatar
13ino13
I'm having similar issues, if not, exactly the same. OP, did you find a solution?
Old Sep 29, 2013 | 04:48 PM
RaceBreed350Z's Avatar
RaceBreed350Z
Check the starter. Look and see if the pos & neg cables are on. Then check fuses.
Old Sep 30, 2013 | 09:23 AM
13ino13's Avatar
13ino13
Thanks, I'll check it out later today
Old Sep 30, 2013 | 05:29 PM
13ino13's Avatar
13ino13
I've checked the connections and the fuses as well, everything seems intact. I also changed out the battery but the it's still doing the same thing.
Old Oct 17, 2013 | 06:36 PM
13ino13's Avatar
13ino13
An update: It ended up being a bad starter. I bought an oriellys one and it makes a weird noise when I start it. Anyone else experience this with starters that aren't OEM?
Old Oct 28, 2013 | 08:49 PM
Bboyjimpy's Avatar
Bboyjimpy
so after replacing the starter, your car started fine? mine is having similar issues
Old Oct 30, 2013 | 02:57 PM
13ino13's Avatar
13ino13
Hey man I know I replied to your pm but thought I'd reply here also so other people would know.
Yea all had to do was replace my starter.
And I'd recommend getting the factory one. Unless you don't mind the ugly noise the aftermarket ones make when you start it. But i guess you can't beat lifetime warranty..
etkms
Jun 19, 2022 06:30 PM
lolwatbro
Oct 9, 2021 04:58 AM
pslamp32
Feb 8, 2017 09:07 AM
350Z Project X
Oct 17, 2015 05:16 PM
Shane86
Sep 17, 2015 05:33 PM
