Water sitting in spare wheel well. Help!
Old May 24, 2013 | 09:05 AM
GothamZ's Avatar
GothamZ
Default Water sitting in spare wheel well. Help!
Hey everyone,
After it rains for a couple days I will sometimes notice a moldy smell. Last night I got to fishing around in the hatch and found the problem. I have water sitting in my spare wheel well. Ive searched but couldnt find much info. Some info here, I have 06+ LED tails in it, so they are not the factory tails, maybe its leaking there? Also, the carpet in the hatch is dry as can be, water it somehow just getting to the bottom of the wheel well and just sitting there. Last night I cleaned it up, and it rained over night, checked it this morning, and water is back, Im just looking for help on where it would be coming in at, i cant seem to find a distinct spot.
Any help is appreciated, id like to figure this out asap.
Thanks
Old May 24, 2013 | 10:09 AM
terrasmak's Avatar
It is usually from the harness connection going to the tail light from the body. I have also sen this problem on prior wreched cars with crappy repairs.
Old May 24, 2013 | 11:01 AM
GothamZ's Avatar
GothamZ
Thanks, Ill check it out. Do you know if its on the passenger side? I noticed there were a few different grommets in the wheel well. Another weird factor is that the after I got the water out last night, my car never moved all night and the water was back in this morning after an overnight rain. So it wasnt even driven, would it still leak from that harness connection from just sitting there?
Old May 24, 2013 | 12:00 PM
Jerry350's Avatar
Jerry350
Had same problem. Just found out that one of the air vents in the back corner of the trunk had a bad seal.
Remove all trim and you'll propably find you have the same issue.
Just ordered replacement part....
Grtz
Old May 24, 2013 | 12:15 PM
GothamZ's Avatar
GothamZ
Thanks Jerry, that could be the same problem im having forsure. Where did you order the replacement vents? Can you easily tell if its bad?
Old May 24, 2013 | 03:53 PM
b18ccivics's Avatar
b18ccivics
take the carpet and floor foam out, get in the back and have somebody hose the car down, watch the water run in then go from there....
Old May 24, 2013 | 07:56 PM
Jerry350's Avatar
Jerry350
It was obvious one of the vents was bad since it was not seated properly in the body and the rubber seal was partly missig.
Used the old 'spray with water from outside' method to make double sure that was the culprit and that confirmed the leakage location.
Ordered part from local dealer at 58,- euro per piece
Good luck!
Old May 25, 2013 | 03:28 PM
GothamZ's Avatar
GothamZ
Yeah ive got all the carpet etc out, im going to have to have someone hose it down and check it out. Thanks for the help guys.
Old Sep 3, 2025 | 02:35 PM
Anthem350z's Avatar
Anthem350z
Grtz
Do you have the part number for this? Any one have a video or photo of what I'm looking for, experiencing the same issue
Old Sep 9, 2025 | 03:43 AM
travlee's Avatar
travlee
Master
he hasnt logged in for 11 yrs....
350z82
Oct 1, 2015 06:25 PM
