Alternator Belt and AC tightness?
Old May 31, 2013 | 06:52 AM
GUz33's Avatar
GUz33
Default Alternator Belt and AC tightness?
New to the 350Z forum just got one a week ago.
My belt came off and had to replace them.
Does anyone have the specs of how tight they need to be?
Thanks!
Old May 31, 2013 | 07:09 AM
GUz33's Avatar
GUz33
btw this is a 2003 350z
Old May 31, 2013 | 07:25 AM
02s2000's Avatar
02s2000
Tighten the adjuster bolts until you have about 8-9mm of deflection on the smaller A/C belt with 22lbs of pressure and 4-5mm of deflection on the thicker belt. Then tighten the lock bolt torquing them to 26 ft-lb. Turn the engine over a few times to let the belts get uniform tension and recheck the belt tensions. When you are satisfied reinstall the under-tray.
this is from the DIY section. there is a whole write up with pictures.
Old May 31, 2013 | 07:33 AM
GUz33's Avatar
GUz33
how do measure deflection? sorry im still new to deflection.
because I think I made the belts too tight.. I can smell rubber burning when im at a stop.
Old May 31, 2013 | 11:50 AM
optimusprim3's Avatar
optimusprim3
This. Here's also a link so you don't even have to search
https://my350z.com/forum/engine-driv...very-easy.html
Old May 31, 2013 | 11:52 AM
iideadeyeii's Avatar
iideadeyeii
Tighten until it doens't slip.
Old May 31, 2013 | 12:51 PM
Jennifer 2's Avatar
Jennifer 2
Guz33, You measure deflection with a simple ruler or tape measure, but you create the deflection by exerting a force on the top run of the belt, (as per the diagram in the link provided by optimusprim and 02s2000).
My neighbor adjusted the larger alt/power steering belt on my car, and he told me that this would be an audience participation event. I was to provide the 22 lb pressure mid span on the belt. He said we didn’t need ‘no stinking belt gage’ and sent me off to calibrate my thumb on the bathroom scale. While I provided a consistent pressure with my thumb, he tightened the adjuster until the belt measured the correct amount, (4.5mm) of deflection. This is the specification for adjusting a belt that has been in service for quite some time.
A new replacement belt will tend to wear into the pulley grooves somewhat, and after a few hundred miles will lose some of its initial tension. This may even cause a few seconds of squealing on a cold start up. Because of this, the deflection measurement for a new belt should be set to a tighter 3.5mm owing to the fact that it will soon ‘wear in’, losing enough tension to end up at the ideal 4.5mm setting.
Old Jun 1, 2013 | 08:16 AM
GUz33's Avatar
GUz33
Thanks! worked on it again earlier this morning so far so good. no slips!
Fixxxercask
Nov 9, 2015 11:10 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
