Leaking FUEL!!
Old May 31, 2013 | 08:21 AM
SoCal-Greenz's Avatar
SoCal-Greenz
Exclamation Leaking FUEL!!
U guys I've been smelling gas inside my Z for a while now and I figured it was cause the o-ring on my fuel pump (passenger side) expanded and didn't seal correctly, when I tried to tamper with that stupid floaty that tells me I'm always empty. But today I was basically empty since iv been keeping track of my mileage and filled up 10 gallons. When I was finished I saw a pool of gas under my rear passenger tire.. I looked under and saw fuel dripping any idea WTF is going on to cause this???
Old May 31, 2013 | 08:45 AM
NissanZguy's Avatar
NissanZguy
Rubber Fuel lines.
Check there first. I bet you have a old fuel line that's corroded and needs to be replaced. Just a guess without actually being able to see the car. Whats the history of your vehicle? Anybody work on it recently?
The rubber fuel lines came from the factory prone to heat/element's corrosion. They did a recall for it which replaced the lines with more durable ones, but im not sure how that works after you've gone over the warranty period. I think a recall should be valid no matter what, but im not sure because i've never been in a recall situation.
GL.
Old May 31, 2013 | 09:49 AM
Syner's Avatar
Syner
Follow the fuel, and find where it is leaking from?
It's not that difficult to look at something yourself
Old May 31, 2013 | 10:40 AM
grimm66's Avatar
grimm66
If you put too much gas in it it will over flow on to the ground... Might have not been as empty as you though.
Old May 31, 2013 | 01:12 PM
SoCal-Greenz
I went to the dealer about the recall and it shows they replaced it back in 06 when I had 60k miles. Now it's 2013 and I'm at 107k.. They scheduled me for Tuesday for a diagnostic
For 50 bucks. But I plan on jacking the car up Sunday and seeing if I can find a leak or corroding hose anywhere. Could anyone direct me which hoses will be fuel hoses?
Old May 31, 2013 | 01:14 PM
SoCal-Greenz
Originally Posted by NissanZguy
Rubber Fuel lines.
GL.
No body work its a clean title but I know it was hit in the front once upon a time. Any idea where I could find a diagram for the fuel lines?
Old May 31, 2013 | 01:15 PM
SoCal-Greenz
Could be that, I filled up only half way 10 gallons and right around 9.5-10 gallons the leaking started to occur
Old May 31, 2013 | 01:29 PM
NissanZguy's Avatar
NissanZguy
Is the leak behind the front right tire or the rear tire?
Old May 31, 2013 | 02:42 PM
Syner's Avatar
Syner
^Said rear in his first post.
Old May 31, 2013 | 06:35 PM
SoCal-Greenz
Infront of my rear tire but way behind the front tire on the passenger side
Old May 31, 2013 | 10:07 PM
terrasmak's Avatar
Prob from the fuel pump area , pinched O ring when you pulled the pump/float.
Old Jun 1, 2013 | 10:06 PM
SoCal-Greenz
Monday I'm going to order a new I-ring and retainer bolt and see what happens. I think that is my culprit since my car smelled like gas and it's basically leaking when my taking reaching over half way. Also last night I poke around with a flash light and realized the light shine to the ground when I look down the fuel pump area...
I'll keep u guys posted with what happens
Old Jun 2, 2013 | 12:56 PM
terrasmak's Avatar
Ive pinched mine once, just pulled it back up and reset it. Its 6 or 8 bolts, just try to reset the O ring.
Old Jun 11, 2013 | 07:58 AM
SoCal-Greenz
So I've ordered a new o-ring and retainer bolt but I will be receiving it the end of this week/ beginning of next week. Ill check back in and let u all know if that fixed my problem or not
Old Jun 26, 2013 | 10:30 AM
SoCal-Greenz
Everything went well with the new o-ring and retainer bolt. No more fuel smell and no more leaking.
Just wish I could fix the issue with the fuel line and floaty saying I have no has after the last quarter tank
derekinthez
South East
Sep 28, 2015 06:35 PM
