The dreaded 3rd gear grind and no warranty, what do?
Old Jun 11, 2013 | 10:08 PM
optimusprim3's Avatar
optimusprim3
Default The dreaded 3rd gear grind and no warranty, what do?
Just today my clutch started grinding into 3rd, even while my clutch pedal was fully pressed in. It doesn't engage for a second or so after I press the pedal to the floor (it takes a full second for the rpms to drop).
Looked it up and saw that other people have had this problem too, except they were still under warranty and had the whole tranny replaced to cd009. Stupid syncro. I however don't think I'm under warranty as I bought it used 2 months ago (it's an 03) and I also don't have $2k cash laying around to replace it... what do?
Old Jun 12, 2013 | 04:31 AM
02s2000's Avatar
02s2000
I bought a used cd009 for $600 online and had it shipped to my installer and he charged $600 for the install.
So total $1200.
Really you got to replace it or live with grind.
Old Jun 12, 2013 | 05:20 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Ha! Love that gif. Funniest part of the movie.
Old Jun 12, 2013 | 05:21 AM
06Gcoupin's Avatar
06Gcoupin
Nothing to do but to replace it.
Just start skipping 3rd gear when u drive.... 1 > 2 > 4
Old Jun 12, 2013 | 05:55 AM
KornerCarver's Avatar
KornerCarver
Maybe try slowing your shifts a little bit.
Old Jun 12, 2013 | 09:06 AM
terrasmak's Avatar
Rev match your shift, drive till it blows , save money for trans till then.
Old Jun 12, 2013 | 10:54 AM
laze1's Avatar
laze1
bite the bullet and replace the clutch and PP while you are at it if you plan to keep the car.
Old Jun 12, 2013 | 05:46 PM
optimusprim3
I did skip 3rd all day today and even 5th as it was grinding this morning.
Yet, when I wanted to show the problem to a friend of mine, it was grind free, even when I shifted fast. My car has a mind of it's own?
Yeah I've seen the $600 CD009's online and I would definitely upgrade to a JWT clutch if I do replace it. I will also put it in myself as my friend has a lift. I will test drive tonight and confirm what's up. Shifting slower is nice and all but I bought this car as a sports car, not a damn minivan
Old Jun 12, 2013 | 06:55 PM
meanz's Avatar
meanz
Save up and wait for a cd09 trans to pop up online and snag it. I got mine off ebay for less than 300 last year and picked it up at the guys house. Install it yourself and save a lot of money and upgrade that clutch/flywheel at the same time.
Old Jun 12, 2013 | 10:30 PM
optimusprim3
This is definitely the best option. I took my Z out tonight and only noticed the grind when I shift fast from 2nd to 3rd in low rpms. When I'm WOT and shifting at ~6600 from 2nd to 3rd fast there is no grind. Also 5th gear doesn't grind at all now. For now, I shall just deal with it
Would changing the transmission gear fluid to Redline MTL/MT-90 mix help at all?
Old Jun 14, 2013 | 07:04 AM
Z-speed33's Avatar
Z-speed33
I had a grind from 1-2 very rarely, when bagging on it usually, and since I changed to redline I haven't had a problem since. so now I use redline for everything. and really it only takes 3L so for the $40 its worth a shot?
Old Jun 14, 2013 | 10:09 AM
meanz's Avatar
meanz
I would def give the fluid a try. It didnt help me out at all in my z though.
Old Jul 12, 2013 | 06:37 AM
nathanwl2004's Avatar
nathanwl2004
had this problem on the cars original trans. replaced with 700 dollar junk yard trans only to find it was funked too, repeated process a few times figuring I would eventually get one that worked. seemed like a never ending cycle till I bit the bullet and dropped in a CD-009 straight out of the crate from nissan. problem solved........ moral of the story do it right the first time and be done with it.
Old Jul 12, 2013 | 08:15 AM
binder's Avatar
binder
You can rev match to eliminate the grind. Cd009 sell for under 1000$ and the transmission isn't too hard to replace. Grab some car guys and drop a little cash to them to replace it if you can't live with rev-matching 3rd.
Old Jul 12, 2013 | 09:45 PM
freddys 350z's Avatar
freddys 350z
i hade a very small grind when going into third when i first got my car 2 years ago. i put redline mt85 and it went away.
only issue i have now is that i cant bang it into second at redline, i gotta wait half a second.
if you have a bad grind, oil wont help you.
Old Jul 15, 2013 | 02:43 PM
oldschool350z's Avatar
oldschool350z
I would learn to live with it until you can replace it.
Old Jul 17, 2013 | 01:05 PM
2003Silver350Z's Avatar
2003Silver350Z
mine did the same thing when she was first getting warmed up in the mornings, i then changed the trans fluid and havnt had any problems since. Changing your trans fluid may be the band-aid instead of stitches solution that your looking for haha. Wont fix the problem but it may help
sherm
Apr 11, 2020 05:21 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Ace2347
Sep 22, 2015 03:12 AM
