Loud Rubbing Squeak Noise When Moving Backwards
Old Jun 18, 2013 | 08:43 AM
pmarascal's Avatar
pmarascal
Default Loud Rubbing Squeak Noise When Moving Backwards
So I first noticed this problem maybe a month ago but the past week or so it has gotten a loot louder. Basically whenever I am moving backwards, whether that be in Reverse or just rolling down my driveway (NOT in gear) I hear this loud noise that sounds like something is rubbing, almost a higher pitched squeak.. but still a rub... It's not 100% of the time, and sometimes it's louder/longer and sometimes it's a half second noise that goes away.
I did just put in a new clutch and lightweight flywheel, but I don't think this has anything to do with it because the noise was happening before. I put it on a jack and looked around, rotated tires backwards (not doing much bc rwd). I didn't see anything out of wack.
I didn't get a chance to check the driveshaft for play, but I did grab tires and check for wheel bearing (12-6) and ball joints (3-9?).. none that I could tell. I know its nearly impossible without hearing the noise, but does anybody have any suggestions before I take it somewhere to put their filthy hands all over it?
EDIT: Its a 2003 5-speed with 90K or so
Old Jun 19, 2013 | 03:07 PM
Tracktimeplz's Avatar
Tracktimeplz
Post a video of the sound, if possible
Old Jun 21, 2013 | 07:08 AM
pmarascal's Avatar
pmarascal
I'll try and grab a video of the sound after lunch today. Obviously it's a shot in the dark, but I read a few things (not 350z specific) that mentioned could be something with the brakes.. either a loose/sheared bolt on the caliper (no idea how that would be sheared) and also somebody reported their e-brake assembly got 'loose' and when moving backwards it shifts to rub... Random stuff, but I'll be tearing into it later tonight to check both of these in the rear.
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
