unknown leak need help (searched)
Old Jul 5, 2013 | 02:03 PM
j_exclusive's Avatar
j_exclusive
Default unknown leak need help (searched)
Hello everybody im new to this forum and I read all the to do's and not to do's if posting. I searched but it all leaded to something else. So here is my problem, I have a 03 touring with 95k miles it runs great but there is a leak by the headers where it bolts to on the engine so I searched the forums and they all say it's the valve cover gaskets, so I checked em and they seem to be fine, I ran my fingers around and along by the valve covers and theyre completly dry..... I know what a valve cover leak is like. I can smell oil burning in my headers when I punch it to high rpms. Please help.
Old Jul 5, 2013 | 07:41 PM
j_exclusive
Bump
Old Jul 6, 2013 | 02:48 AM
j_exclusive
Really? No effin help? Bump
Old Jul 6, 2013 | 03:54 AM
Touge Z's Avatar
Touge Z
do you actually see oil anywhere or just burning on the headers?
Old Jul 7, 2013 | 12:24 PM
j_exclusive
i see oil man by the headers
Old Jul 7, 2013 | 12:59 PM
Classy's Avatar
Classy
I know it is a tight spot, but a picture would help alot
Old Jul 7, 2013 | 01:22 PM
Kunihiro's Avatar
Kunihiro
is there any oil on the ground where your car sits? If so, is it toward the front or rear of the motor? Is there a drop in oil pressure? Could it be a leaking oil sending unit?
Just a thought..
Old Jul 7, 2013 | 08:02 PM
j_exclusive
Just a thought..
no oil leaks on the ground, here is a pic, i ran my fingers thru the valve cover and underneath (where the blue line is) it seems clean. leak is coming from the headers.
Old Jul 7, 2013 | 10:46 PM
meanz's Avatar
meanz
Prolly just a leaky valve cover dripping onto the exhaust. I couldn't ever see the leak till we removed valve covers. Does it have light smoke coming up? Mine smoked, but only certain conditions.
Old Jul 7, 2013 | 11:44 PM
KnightHawkUSMC's Avatar
KnightHawkUSMC
if you say you checked the VC gaskets and were dry, and you smell oil at high rpms coming from your headers, have a friend or relative follow you a short distance to see if they can smell burning oil behind you and/or see bluish smoke. if so then you might have bad oil rings. at 95k its highly unlikely but again I've experienced stranger things. if no smell or smoke, best bet would probably be to just replace the VC gaskets...I don't know about the Z but every other car I've owned they been 20-30 bucks each
Old Jul 9, 2013 | 10:40 PM
j_exclusive
ok ill try replacing the vc then
Twenty4
Jan 17, 2016 01:20 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
