VDC relay
Old Jul 31, 2013 | 01:24 AM
JDMStanced's Avatar
JDMStanced
Default VDC relay
Does 2006 g35 coupe manual transmission have same VDC relay as 2005 350z manual?
my 350z has slip and VDC lights on so i was wondering if i could swap g35's relay over to see if it's caused by the blown relay.
thanks
Old Jul 31, 2013 | 01:39 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Should be but I'm not the technical one....if it does blow then the IPDM is shorted. I think I saw your other thread where you think it's linked to the mod, but I highly doubt it.
good luck
Old Jul 31, 2013 | 01:42 AM
sracura's Avatar
sracura
I used an 05-350z relay on my 04-G35 it works like it should, hope this helps
Old Jul 31, 2013 | 01:44 AM
JDMStanced's Avatar
JDMStanced
Are they both manual? If that makes any difference
Old Jul 31, 2013 | 02:56 PM
DirtyMech.'s Avatar
DirtyMech.
A relay is a relay. Pull it out and compare it.
Old Aug 3, 2013 | 03:06 PM
JDMStanced's Avatar
JDMStanced
I tried it. VDC relay seems fine. I don't know what else could be wrong ..
Old Aug 7, 2013 | 09:56 PM
DirtyMech.'s Avatar
DirtyMech.
since you have lights on have you tried looking up the codes... probably the best place to start.
Old Aug 7, 2013 | 10:13 PM
JDMStanced's Avatar
JDMStanced
I always had vdc and slip lights on but when I had the car smog checked, abs light came on too.
I had a shop scan the code but scanner didnt show any problem.
Abs light went away after driving for awhile. But vdc and slip lights remained on.
aarrgghh
May 1, 2022 11:04 AM
Workshop12
Mar 23, 2020 01:45 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
Beater350z
Sep 9, 2015 03:36 PM
