Misfire diagnosis
Old Sep 10, 2013 | 11:43 AM
Resmarted's Avatar
Resmarted
Originally Posted by rorii
Update: had a chance to work on the car and removed all injectors. Got it flow tested and found one of them had an erratic spray pattern. But flow is pretty consistent on all 6.
Is the spray pattern enough to cause the misfire?
If it was, pulling the coil on that cylinder would cause the missfire to go away. To verify swap that injector around and mark it. Then pull the coil on the cylinder that has the injector in question.
I can't play your videos here, so ill watch them later
lolwatbro
Oct 9, 2021 04:58 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
krazE
Oct 21, 2005 12:47 PM
sentry65
Jan 14, 2005 08:51 PM
350Zzzz
Dec 16, 2003 08:12 PM
