Sounds like a bearing issue but is not..
Hey guys, I'm getting a metal grinding/rubbing/whirring noise coming from my rear end. It sounds exactly like bad bearings. So much so that Nissan and 2 other independent mechanics told me it was the bearings. After replacing both rear bearings the noise persists. What sounds like bad bearings but isn't?
Some info:
There is no play at all when I put the car on stands and work the tire. Everything feels tight. I recently got all new tires, the noise happened before and after. It seems like the sound is worse when coming to a stop. The sound seems louder if I come to a stop in neutral. If I come to a stop in gear I can barely hear it, if at all. The sound appears to be getting louder/worse. Sometimes my parking break 'sticks' so when I give it a little gas there is a breaking noise in the back, a mechanic said this had nothing to do with the whirring noise, just thought I'd mention it. I'm at a loss, even if I start pulling **** off I'm not sure what I'm looking for. I have a friend at Tire Kingdom, he suggested looking at the gears. Is there anything I should check?
Some info:
I had a noise that sounded like I was dragging a stick behind the car. I thought sure it was a bearing, but just wouldn't accept that it would go out with less than 10K miles on the car. I could hear a slight ticking noise if I pulled up or pressed down on the fender.
It turned out to be the rubber bushings at the top of the left shock absorber. I disassembled the bushings from the top mounting bracket, applied liberal amount of silicon grease, and reassembled things. The noise was gone.
