some issues on my 03 350z
Old Sep 4, 2013 | 02:41 AM
375rngrZ's Avatar
375rngrZ
Default some issues on my 03 350z
im having some issues on my 03 350z i bought it back in march with 69k miles and ive noticed some issues that i want to try and fix before having to take it to get looked at. first when the car is around 70 miles an hour if you hold the rpms steady i get a weird whistle/squeel sound but its only if you try to hold it steady. second when im barely moving in first or reverse the power steering is non existent and as you give it more gas it slowly fades in but even when it fades in i dont think it is fully working. and last once in awhile (it seems to be becoming more frequent) when i let off the gas completely after accelerating i seem to get a vibration sound and my shifter gets alot more vibration to it if you pump the clutch once it goes away. im sorry if any of these questions sound noobish im still trying to get more mechanical with cars but any help is greatly appreciated.
Old Sep 7, 2013 | 07:05 AM
375rngrZ's Avatar
375rngrZ
any advice or suggestions would be a help im currently deployed id like to have an idea of what i have to fix before getting back
Old Sep 7, 2013 | 01:12 PM
Suwaidi's Avatar
Suwaidi
For the near non-existent power steering fluid, pop the hood and check the fluid levels, and top off if needed.
http://www.conceptzperformance.com/c...1866.249.73.37
Not sure about the other issues though, sorry!
Old Sep 8, 2013 | 12:03 AM
375rngrZ's Avatar
375rngrZ
yea it has fluid thats definitely not it
Old Sep 8, 2013 | 09:35 AM
bealljk's Avatar
bealljk
So if its not fluid I would look into your ps pump. It's not hard to swap out. As far as your vibrations go I would make sure your wheels/tires are balanced before you get too deep into anything, there may be more to it with your clutch pumping?? the squealing maybe a something on your belts or quite possible a wheel bearing…
You mentioned 70mph as the trigger for the sound…can you go 70mph in 6th gear versus 70mph in 4th gear and does the sound remain? if you can rule-out the engine speed variable you can narrow down your diagnosis area - I would assume with 70k miles you have a wheel bearing on it's way out. And vice-versa, if the squeal is at a specific RPM (and not a speed) then you can look into your belts and ps/alt/AC setups
where are you deployed to? Thank you for your service - work safe!
Old Sep 8, 2013 | 10:20 AM
Jah70's Avatar
Jah70
My shifter rattles when I get on the gas at all even just slightly. The whistle sound though. Do you know if the car was slightly modified? That sound might be a intake/plenum issue like someone putting a spacer on wrong or without a gasket.
Old Sep 8, 2013 | 12:55 PM
bealljk's Avatar
bealljk
mine too, but just slightly, enough to make me not really do anything about it.
def a possibility but wouldnt it squeal more or less depending on speed and/or engine speed?
Old Sep 9, 2013 | 06:58 AM
375rngrZ's Avatar
375rngrZ
im not sure its not an rpm issue it only does it in the range from like 70 to 80 and only if im trying to cruise at it if im accelerating it doesnt do it. as for the shifter vibrations its very noticeable it sounds like your hitting the rumble strip on the side of the road but as soon as i pump the clutch or give it a decent amount of gas it goes away im really just trying to make sure it isnt a trans issue thats all i need. and thank you for the thank you im doing my second tour in afghanistan.
Old Sep 9, 2013 | 06:59 AM
375rngrZ's Avatar
375rngrZ
as for the squeel i honestly dont know if it was modified but i just bought a spacer so ill find out when i get back to the states lol its honestly nothing im worried about but its embarassing when you drive a nice car and it makes obvious noises like that lol
Old Sep 21, 2013 | 07:30 AM
375rngrZ's Avatar
375rngrZ
thanks for everyones help on this im really trying to focus in on the power steering problem. nissan recently quoted me 1200 to fix the power steering pump which is ridiculous. but im not sure what to expect for a price on a new power steering pump and steering rack plus install, anyone done this and know around what i should spend?
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
Ronso
Oct 30, 2015 12:39 PM
issyz
Sep 12, 2015 04:18 PM
Darkspy
Sep 7, 2015 09:09 PM
