alignment gurus chime in (print out attached)
Old Sep 11, 2013 | 06:22 AM
softbimbo's Avatar
softbimbo
Default alignment gurus chime in (print out attached)
just got an 07 stock suspension, front tires were more worn on the inner edge, really bad noise between 20-30mph and during braking. got an alignment done last week. wondering if someone can make sense of these specs.
I'm guessing toe is what caused the wear? i know camber is unadjustable. my question is if i remounted the tires on opposite sides could that help with the noise and even out wear? ie flipping the inner edge to be on the outside
Old Sep 11, 2013 | 06:28 AM
softbimbo's Avatar
softbimbo
print out
Attached Thumbnails alignment gurus chime in (print out attached)-350-alignment-specs.png
Old Sep 11, 2013 | 06:37 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I'm guessing the previous owner was the cause of the tire wear and the dealer did an alignment before selling you the car. Even before your alignment you weren't very far out of spec; not enough to cause camber wear at least.
Old Sep 11, 2013 | 10:35 AM
Syner's Avatar
Syner
I was in the same situation last summer. Remounting will help with noise, but will not even out wear.
Old Sep 14, 2013 | 06:18 AM
softbimbo's Avatar
softbimbo
had them remounted, way quieter. thanks
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
