2008 350z low oil pressure on external gauge
Old Sep 13, 2013 | 05:43 AM
OntarioGuy's Avatar
OntarioGuy
Default 2008 350z low oil pressure on external gauge
Hello Everyone, im new here, i joined because im having an issue with my VQ35HR with 51k miles
basically my oil pressure gauge in the car has been showing below the halfway point between 0-30
the FSM says it should be over 14psi at idle, mine was showing low so the dealer checked with a external gauge to make sure it wasnt the sending unit or the sensor. It read 11.61 psi at idle FSM states over 14PSI the dealer said its within spec and not to worry? Are they trying to pull a fast one on me, im going to call the service manager today, just wanted to get opinions from you guys.
is this acceptable? maybe my oil pump is going out, maybe something worse?
thanks
Old Sep 13, 2013 | 05:49 AM
redline06's Avatar
redline06
Take a pic of your gauge at idle and at operating temp. Mine has always been very close to the first line and im at 127K now without issues. I did notice slightly higher pressure at idle when I switched from Mobil1 to the new Penzoil platinum oil which I'm very impressed with btw lol
Old Sep 13, 2013 | 05:58 AM
OntarioGuy's Avatar
OntarioGuy
its not close to the first line, its below half way to the fist line, ill try and post a pic later, although it should be pretty straight forward as to what an external gauge looks like when it reads 11.6 psi :P
Old Sep 14, 2013 | 07:43 AM
OntarioGuy's Avatar
OntarioGuy
Any opinions? Bump
Old Sep 14, 2013 | 04:38 PM
mcarther101's Avatar
mcarther101
I assume you have checked how much oil you have added and aren't low?
Read this:
http://www.international-auto.com/fi...ure-gauges.cfm
Oil px doesn't change for no reason. If its out of FSM limits, it is serious.
Old Sep 15, 2013 | 05:39 AM
OntarioGuy's Avatar
OntarioGuy
thanks for the read, my oil prerssure seems fine at other rpms above spec, there are no engine noises or knocking of any sort that concerns me. its just at idel after the cars been fully warmed up run on the highway to work etc
delaer wants to bring it in again, and retest with new gauges
if it tests like this again what do i push for? i snuck it in under warranty close to the last day lol, and have documented with nissan head office whats been going on
Old Sep 15, 2013 | 09:15 AM
mcarther101
If you got it in on the last day of warranty, I'd definitely keep good records. If your problem develops into something serious, and Nissan subsequently dicks you around I'd consider legal action if necessary. Might be able to argue that they didn't want to cover it under warranty, and hoped you would just go away until after the warranty expired.
Old Nov 16, 2013 | 07:17 AM
Richf's Avatar
Richf
Any update on this
My 07 model is the same , although the car seems fine the oil pressure on hot idle is about 10psi
Old Nov 16, 2013 | 01:11 PM
winchman's Avatar
winchman
What's the oil pressure at other engine speeds when the engine is warmed up?
How long has it been since you changed the oil and filter? Are you certain the correct weight oil was used? With so many new engines using very thin oil, it would be easy for a quick-change place to use the wrong kind.
Old Nov 16, 2013 | 02:05 PM
Richf's Avatar
Richf
Just changed the oil and filter for motul 5w40 as recommended by my tuner , oil is up to the upper level
At 3000rpm it's up to 30/40 psi it will go over 60 at higher rpm but it's always lower than spec
Removing the oil filler and I can see plenty of oil splashing around on the cam
Car drives fine with no noises , rattles or knocking
Old Nov 30, 2013 | 02:40 AM
Richf's Avatar
Richf
removed
Old Nov 30, 2013 | 04:42 PM
guitman32's Avatar
guitman32
If not something like a bad oil pump or clogged pickup tube, likely an indication of worn bearings inside the motor. Plumbing an external gauge could also help eliminate some uncertainty.
Old Nov 30, 2013 | 09:55 PM
Richf's Avatar
Richf
removed
Old Dec 4, 2013 | 06:40 AM
Richf's Avatar
Richf
removed
Old Mar 26, 2014 | 04:50 PM
kysersolze350Z's Avatar
kysersolze350Z
Talking
my 2008 at 60k does the same exact thing and every dealer ive called says its perfectly normal,not to worry,,,,at operating speeds my gauge is dead on but at idle at running temp it stays at like 10 ,,,ive called and called ,theres no knocking in motor ,sounds great,all stock,,just had oil changed put penzoil 5-30 in it and I just bought it 4 months ago.......It runs great IDK
Old Mar 26, 2014 | 05:18 PM
Jbakes727's Avatar
Jbakes727
I have an 04 with 95k but my gauge always reads 90 right away on a cold start, 25-30 idling (with a/c on), 60 cruising, and around 90 WOT. If I turn my a/c off it goes to about 15-25 idling. Honestly if mine was reading that low I would look into it but only because mine has always been around 30 psi at idle.
m_0g
Jun 3, 2021 10:05 AM
350z_z33.
Sep 9, 2015 09:50 PM
Inspatatrac
Sep 8, 2015 02:12 PM
Darkspy
Sep 7, 2015 09:09 PM
