350Z: Auto Trans, Manual shift doesn't work
Old Sep 27, 2013 | 11:47 AM
emartin30's Avatar
emartin30
Default 350Z: Auto Trans, Manual shift doesn't work
I just bought a 2003 350Z. The manual shift of the AT doesn't work. It will shift down but not up. I would like to know how this thing works. Is it just a switch closure that tells the car to shift or is it mechanical?
Any help or link to how it works would be greatly appreciated.
Old Sep 27, 2013 | 06:32 PM
Old Rice's Avatar
Old Rice
Somewhat of a guess but maybe electronic issue in the JATCO TCM.
http://www.atraonline.com/gears/2007...2007_01_12.pdf
Maybe try a reset as described in link.
Old Sep 28, 2013 | 09:09 AM
emartin30's Avatar
emartin30
Good article but says a reset is turning the key off for 10 seconds and then back to the on/run position. Seems like it would reset every time you turn the engine off. Am I missing something?
Old Sep 28, 2013 | 10:18 AM
jerryd87's Avatar
jerryd87
more then likely not having trouble to get it to load but most of the time if it has a time limit such as turn it off for 10 seconds then back on then it has a limited window where it is keeping track of time and only does it in that window. that is done for the specific reason you say so it wont reset everytime
Old Sep 29, 2013 | 01:56 AM
emartin30's Avatar
emartin30
Not really acting like any scenarios in the article either. Car goes in all 5 gears. The only problem is the manual shift mode and it only won't shift up. Its shifts down fine. I figured someone on here would know how it works.
Old Sep 29, 2013 | 02:12 AM
dcains's Avatar
dcains
Simple - but did you check the fluid level?
Old Sep 30, 2013 | 09:09 AM
waldo36's Avatar
waldo36
Do you know how to check and make sure your servos are making good enough contact to activate? If not, I can post some pictures on how to remove the shifter cover and check the servos.
Old Apr 6, 2014 | 01:17 PM
ohmicide's Avatar
ohmicide
I need some help with this, my manual shifting works but sometimes doesn't catch the shift and I have to do it again and I can't seem to find any info on how troubleshoot the problem
Old Apr 6, 2014 | 02:25 PM
JCITY's Avatar
JCITY
Do you have a OEM shift lever or,has a aftermarket like a Momo been installed?
Old Apr 6, 2014 | 03:14 PM
ohmicide's Avatar
ohmicide
stock
Old Apr 6, 2014 | 04:52 PM
myfirstzcar's Avatar
myfirstzcar
Check for codes and check the fluid level. Manual mode will not work if there are certain faults in the tcm.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
seagrasser
Oct 11, 2015 03:27 PM
Tomek350Z
Suspension
Oct 11, 2015 08:32 AM
Shane86
Sep 17, 2015 05:33 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
