07 P0507 Code and slow idle drop when code is off
Old Oct 11, 2013 | 08:57 AM
Vince2133's Avatar
Vince2133
Default 07 P0507 Code and slow idle drop when code is off
So I have a 07 and I did not remove the TB to clean it or anything, it throws the 0507 code (high idle) here and there, but I've noticed even when the code is off, the rpm will stall at 1500 rpm for about 2-3 sec then drop down to 600.....help.
Old Oct 11, 2013 | 09:05 AM
travlee's Avatar
travlee
Master
sounds like you need to do the idle air relearn
Old Oct 11, 2013 | 03:03 PM
Vince2133's Avatar
Vince2133
Been there done that, maybe I'll do all 3 of the relearns together, but it doesn't make sense to me that the idle is weird without the code being on.
Old Jan 18, 2014 | 03:59 PM
dilat3d's Avatar
dilat3d
Did the relearns fix your problem?
Old Jan 18, 2014 | 06:14 PM
myfirstzcar's Avatar
myfirstzcar
I would start by cleaning the Tb. 600 rpm is a decent normal idle for the Z, and that code is most likely not a "first trip" code.....Meaning that it's allowed to happen at least once without setting a code.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
