Parking light not working
Old Nov 21, 2013 | 10:17 AM
corey92p's Avatar
corey92p
Exclamation Parking light not working
New to the forum and my first post!
I recently decided to switch out my parking lights in the front, to LED lights. I am not sure if this problem began before my switch or not, but I noticed after I installed the LEDs. After installation I noticed the front driver-side parking light works properly, however the passenger-side will not turn on. I've tried multiple bulbs in case I had a faulty LED and it never turns on. Are there different fuses for the driver's side and passenger-side parking lights? Any suggestions what to do? If this is an easy fix, I really don't want to go to the shop and get robbed.
Thanks
2005 350z touring
Old Nov 21, 2013 | 01:02 PM
SQuaLZ's Avatar
SQuaLZ
Did you try rotating the bulb and plugging back in? Those bulbs have a positive and negative and they only work one way, which is why I test before putting everything back.
To my knowledge the left and right headlights are separate fuses. Did you try the stock halogen after to see if that worked?
Old Nov 21, 2013 | 03:01 PM
corey92p's Avatar
corey92p
The headlights work properly, but rotating the bulbs is one thing I did not do. Maybe there's some chance that I had every bulb I tested the wrong way. I will check again tomorrow, making sure to rotate it just in case. I'll also try to see if there's an issue with the fuse.
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
Shane86
Sep 17, 2015 05:33 PM
