HELP! Throttle hesitation in any gear
Old Nov 27, 2013 | 08:36 PM
solidsnake's Avatar
solidsnake
Default HELP! Throttle hesitation in any gear
Replaced crank/camshaft sensors. Didn't fix the issue. Not throwing any codes or CELs. The issue is a slight hesitation in acceleration after shifting gear. Also inconsistant acceleration. Example: using cruise control it turns off because a loss of power. I am not sure what else to replace since no codes. Took to nissan and ran diagnostic on their machine and all checked out okay. I thought throttle position sensor but I cannot find the replacement part online. Any ideas would be cool before I blow money on a mechanic
Old Dec 25, 2013 | 03:42 PM
solidsnake's Avatar
solidsnake
Any input? I took it to autozone and diagnostic machine came up clear with NO codes.
Old Dec 26, 2013 | 03:11 PM
Spike100's Avatar
Spike100
I would test the TPS (voltage and ohms). It may just require an adjustment.
--Spike
Old Dec 28, 2013 | 12:29 AM
solidsnake's Avatar
solidsnake
The odd thing is. If run the car all day. The second to third startup the cat runs fine. No issues. Its as if its worse the longer car is idle like when I leave for work in afternoon after it sitting all night in garage.
Old Dec 28, 2013 | 12:48 AM
1sickveilsidez's Avatar
1sickveilsidez
Did you replace all 3 sensors with factory ones?
The throttle sensor is part of the actual throttle body, you can not get the sensor separate. If you do need to replace it, you will need part number 1611K-8J10BRE.
Only other thing I can think of is the VTC sensors.
Old Dec 28, 2013 | 04:11 AM
myfirstzcar's Avatar
myfirstzcar
Water and/or garbage in the fuel tank.
Old Dec 28, 2013 | 09:01 AM
solidsnake's Avatar
solidsnake
Honestly didnt replace with OEM sensors. Went to advanced auto parts. I am considering getting all the OEM and see if that helps. Dont think it's bad fuel since ive filled tank up three times with different gas each time.
Old Dec 28, 2013 | 09:46 AM
1sickveilsidez
That's a good start, working at the dealers for such a long time you see a lot of things like this.
We always get customers that come in for the cam and crank sensors problem, we give them an estimate and then they go get aftermarket ones to save some money. Few days or weeks later they come back with the same problem and purchase factory ones and problem solved.
Not saying that aftermarket is bad, sometimes the parts work just the same. Not 100% sure that's the problem with your car, but from what you described it could be it. Hard to diagnose without seeing the car in person.
Old Dec 28, 2013 | 10:00 AM
oldschool350z's Avatar
oldschool350z
I would get oem ..just to be certain.
Old Dec 28, 2013 | 10:19 AM
Spike100's Avatar
Spike100
You provide very good advice here. I would definitely go with OEM since the price difference is minimal. I also would replace both banks (camshaft sensors and crankshaft sensors) if the car has over 80K miles.
I also got a code for bad O2 sensor, but did not replace this. Replacing the other sensors removed the bad O2 sensor code.
TPS could be the problem here, and as you state, a faulty TPS requires replacing the Throttle Body. It is possible to test the TPS using a multimeter (you need to test both voltage and amperage).
--Spike
Old Dec 28, 2013 | 12:11 PM
travlee's Avatar
travlee
Master
I have heard of so many people getting after market sensors and having issues with them
Old Dec 28, 2013 | 12:32 PM
Spike100's Avatar
Spike100
I've heard of this as well, but don't know for sure. It would be helpful if you can direct us to those people you mention.
--Spike
Old Dec 28, 2013 | 07:28 PM
myfirstzcar
--Spike
This thread is full of crazy stupid advice.
YOU HAVE NO CODES....as per post #1. What would make anyone think it's a sensor?...Specifically, what would make anyone think it's a tps sensor?
You need to add a little dry gas first, to eliminate the possibility of water in the tank, I don't care how many times you've filled it.
If that doesn't work then let me ask, do you have a cold air intake?
Old Dec 28, 2013 | 08:05 PM
1sickveilsidez
Another thing I just thought of is possibly the MAF sensor. Like I said hard to diagnose the car without seeing it in person, but those are the first things I would look in to.
Old Dec 29, 2013 | 04:32 AM
myfirstzcar
The maf is a possibility, especially if you have a cai.
Old Dec 29, 2013 | 09:16 AM
Spike100's Avatar
Spike100
Sometimes you get a code seemingly unrelated to the problem, and sometimes you don’t get a code at all. What’s confusing here is he reports that the problem is intermittent. No one mentions a loss of vacuum.
YOU HAVE NO CODES....as per post #1. What would make anyone think it's a sensor?...Specifically, what would make anyone think it's a tps sensor? …
Old Dec 29, 2013 | 10:06 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Crazy stupid advice huh........ Maybe if you were a OG member like some of us here these stupid tips should help or fix. I work in the field as well and ANY time we have a Nissan here with codes or similar problems we always replace with OEM nissan sensors. and guess what? No problems. ANd since this is your "first" Z car maybe you should sit back and STFU and listen as well.
Old Dec 29, 2013 | 01:47 PM
myfirstzcar
Who said anything about vacuum?
OOOOH tough guy huh? My "firstZcar" was 5 years ago now. I've been working on cars for over 25 years and haven't paid a mechanic for anything in over 10.
I'm not against oem parts either. What I am against is people throwing parts at a vehicle and hoping for the best......Learn how to diagnose! If the car has no codes, you look for the obvious, like water in the gas, bad wires/grounds etc. My car had a bad knock sensor for at least 100 miles before it threw a code, and the CEL hadn't even lit up yet. So in the meantime, look at the obvious, and keep checking for codes.....OG....Your forum experience doesn't trump my real-world experience so butt out!
Old Dec 29, 2013 | 02:08 PM
Spike100's Avatar
Spike100
[QUOTE=myfirstzcar;10296311]Who said anything about vacuum? …/QUOTE]
OK… I’m thinking you are one of those people who post when they have no idea. An analysis of your posts supports a lack of knowledge.
You talk about mice causing a problem with a car, lack knowledge about codes, and generally seem ignorant about car repair.
--Spike
Old Dec 29, 2013 | 03:16 PM
2004Black350z
Exhaust Whore
havent paid a mechanic for anything but created a thread years back about grounding kits and do they work....? LMFAO
