Steering Turning to the Right
Old Dec 3, 2013 | 07:45 AM
skeetz9r's Avatar
skeetz9r
Default Steering Turning to the Right
I have a 03 350z. Yesterday when I started to drive my car I noticed a weird problem. My streering wheel keeps swerving to the right, little by little on regular intervals, like every 2 seconds. It turns to the right side probably 5 degrees or so and then a little more and more and so on. So I had to keep a tight hold on the steering to make sure it doesn't.
Any ideas? I checked all the lugnuts and tire pressure and everything was fine. I did not hit or run over anything either, it's just strange. Have owned the car for a while now without any issues.
Old Dec 3, 2013 | 08:51 AM
Zmandriving's Avatar
Zmandriving
check sway bars and endlinks. is there any play in your steering wheel. When my endlinks went the steering felt real loose. You should jack your car up and look at suspension parts to look for any worn parts. If you are not sure take it to an experienced mechanic.
Old Dec 3, 2013 | 01:26 PM
winchman's Avatar
winchman
Email Rush Limbaugh. He might like it like that.
Old Dec 3, 2013 | 07:40 PM
TuckerE36's Avatar
TuckerE36
OP did it ever occur to you that your Z might need a front end alignment???
Old Dec 4, 2013 | 05:39 AM
terrasmak's Avatar
Alignment and the tires are cupped. Sway bar will have nothing to do with that.
Old Dec 4, 2013 | 11:01 PM
winchman's Avatar
winchman
Could also be something wrong with the rack and pinion steering system.
Old Dec 5, 2013 | 05:21 PM
Spike100's Avatar
Spike100
Based upon the problem description, I'm going to say that it's obviously alignment.
--Spike
Old Dec 8, 2013 | 09:23 PM
jds4181t's Avatar
jds4181t
if you haven't taken it to the shop yet you can try swapping the front wheels and seeing if it pulls the other way, then again i'm posting this pretty late..
sherm
Apr 11, 2020 05:21 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
