engine freeze?
Old Dec 12, 2013 | 02:45 PM
JDMStanced's Avatar
JDMStanced
Default engine freeze?
i live in detroit where the weather gets lower than 19 degrees..(could go down to 0)
When i changed coolant, i think i put more of water than coolant.
Would storing the car in the parking structure for a month cause the coolant/water to freeze over time? I hope not..
thanks.
Old Dec 12, 2013 | 02:55 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Yes if it's too much water. Bad bad bad
Old Dec 12, 2013 | 03:03 PM
JDMStanced's Avatar
JDMStanced
Too much as in... almost water?
Should i simply empty the coolant reservoir and add water and coolant half and half? ..got no energy to drain coolant lol
I think when there was air in the system after thermo change or coolant change, i put water to fill in the system.
Old Dec 12, 2013 | 05:51 PM
KornerCarver's Avatar
KornerCarver
You can get a very cheap tool to determine how cold your engine is protected. Go to Autozone and buy a coolant tester. It is a very cheap instrument and could prevent a catastrophic motor problem.
http://www.autozone.com/autozone/acc...ester/_/N-256i
Old Dec 12, 2013 | 09:40 PM
cudaben's Avatar
cudaben
+1 ^^^^ great way to be sure.. But make sure to run your car for a while and then let it cool to test. if you have jut added water to your tank then test it.... it will likely say add coolant. Picking up what im putting down?
Old Dec 12, 2013 | 09:57 PM
Jennifer 2's Avatar
Jennifer 2
Since a 50/50 antifreeze / water mix will not start to freeze until –34 degrees F you probably still have a fair amount of safety margin. However, the 50/50 ratio also raises the boiling point to 226 degrees F so it’s worthwhile to correct your mixture.
Old Dec 13, 2013 | 02:47 AM
POS VETT's Avatar
POS VETT
I'd be a whole lot more motivated and be much more energized to put in correct coolant mixture knowing that frozen coolant would crack an engine block, but that's just a silly old me.
Old Dec 13, 2013 | 03:30 AM
NOLAGG's Avatar
NOLAGG
^ indeed happened to my friends SR20 a month after it was bought here in nyc but the problem was there was only like 29 % coolant . Wasn't pretty .
Old Dec 13, 2013 | 04:36 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
what a lazy dumbass. I hope you freeze your block and crack it.
too laxy to be bothered to spend 30 bucks of coolant to prevent paying out the *** to swap in a motor.
op creates nothing but stupid question threads on herem not sure why its tolerated.
search and stop cluttering the forum with your stupidity
Old Dec 13, 2013 | 05:01 AM
travlee's Avatar
travlee
Master
dont have the energy to drain coolant huh?? then you must have the money to replace an engine. why would you risk that
Old Dec 13, 2013 | 05:39 AM
Syner's Avatar
Syner
If you don't have the energy, leave it.
*waits for "my block cracked" thread next spring*
Old Dec 13, 2013 | 08:04 AM
JDMStanced's Avatar
JDMStanced
Wait for selling a Z threadr cracking the engine lol
Thx for help guys
Old Dec 13, 2013 | 12:45 PM
GOGOZ's Avatar
GOGOZ
thanks.
Judging by your "Deep in Irvine" signature, it doesn't seem like you're from Detroit.....
Get off your a** and flush the water out now- you don't want to be stuck in Detroit with a Z stuck in a parking structure unless your "parting" out the car for "free"
Things go missing around here very easily- cracked block will be the least of your worries
Old Dec 18, 2013 | 09:09 AM
NOLAGG's Avatar
NOLAGG
Did your block freeze yet? Or did you flush the water
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
