Something wrong with 350z please help!
Old Dec 12, 2013 | 09:04 PM
EricAshes's Avatar
EricAshes
Default Something wrong with 350z please help!
Well let me start off first by saying that it is getting really cold here and it snowed a lot over the weekend and I have been having to drive over ice to get to work in my 350z. Today when I got off work I turned my Z on and it was fine nothing wrong. However after about 2 miles of driving the brake light pops up and won't go away. (I never use my parking brake so thats not it). I checked my parking brake, its off. I stomp on the pedal, nothing is wrong. I turned my car off and on its still there. What is wrong? I read in the owners manual if you have low brake fluid it will turn on when you brake or go excessive seeds. But this is STAYING on.
Old Dec 12, 2013 | 09:13 PM
dcains's Avatar
dcains
So, did you check the brake fluid level?
Old Dec 12, 2013 | 09:30 PM
Jennifer 2's Avatar
Jennifer 2
Eric, the light is there for a reason. As you have already checked to see that the hand brake lever is all the way down, the next thing to check is the brake fluid level in the master cylinder. Yes as the fluid drops to the point where the float just barely closes the light switch contacts the dash light will flick on with hard acceleration or hard braking. However, this is just the fluid sloshing up and down in the reservoir. With just a slight more fluid drop the light will stay on all the time.
If there are no obvious leaks, this is simply an indication of brake pads that at their wear limits. As the pads wear, the caliper pistons automatically self adjust inward, this requires fluid to flow from the master cylinder reservoir to the calipers. The light comes on to indicate a brake inspection is needed as the pads are now excessively worn.
Old Dec 13, 2013 | 11:26 AM
EricAshes's Avatar
EricAshes
Thanks for the reply Jennifer. Brake fluid seems ok, pads have quite a bit of wear but nothing that would seem to make it a problem.
Its worth noting about a month ago when it got cold my tire pressure light came on and I have made sure countless times all my tires are at 30-35 (changed countless times seeing what works nothing does). The light is still on.
Maybe these two problems go hand in hand and a sensor is broken?
Old Dec 13, 2013 | 11:30 AM
travlee's Avatar
travlee
Master
are you sure that you have the sensors in the tires? for the brake, try topping it off.. it has a black rubber thing that sucks down when it is low... are you sure you are not seeing that
Old Dec 13, 2013 | 12:36 PM
Jennifer 2's Avatar
Jennifer 2
Well you have to go step by step to troubleshoot. Start by Inspecting the operation of the handbrake switch to be sure it’s not loose or malfunctioning. Also check down into the brake fluid reservoir to make sure the float is floating and not stuck down etc.
Old Dec 20, 2013 | 03:23 PM
EricAshes's Avatar
EricAshes
Forgot to reply. Thanks for the help, sensor wasn't working right it's all good now .
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
