Yellow sandy substance in radiator
Old Dec 13, 2013 | 07:51 PM
350z-Na's Avatar
350z-Na
Default Yellow sandy substance in radiator
Hey guys, I'm in the process of fully draining my coolant system, and I noticed that there is yellow sandy substance in my radiator. The water looked clean while draining it. I check my oil every week and the colour is normal like always.
What do you guys think it could be?
Old Dec 13, 2013 | 09:02 PM
Sean's Avatar
Sean
I need to see it, I think there are a couple things it could be. Corrosion, a dissolving seal in the coolant system, water-pump bearing, or the prior owner added a chemical to the coolant system that is now breaking down (like a Gumout or a leak stopper).
Old Dec 14, 2013 | 05:14 AM
350z-Na's Avatar
350z-Na
Ok, i will post some pictures once i get home.
Old Dec 14, 2013 | 06:07 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
threads like this blow me away. Want help but dont have anything to help us
Old Dec 14, 2013 | 08:14 AM
350z-Na's Avatar
350z-Na
I didn't think i would've need to post pics, since i pretty much described it. I will post pics once i get home from work. My bad though
Old Dec 14, 2013 | 05:08 PM
350z-Na's Avatar
350z-Na
Old Dec 14, 2013 | 06:45 PM
Sean's Avatar
Sean
The picture is no help this time. drain the coolant through paper in a strainer. Once it dries, take a picture of that and let us know if it feels metalic.
Old Dec 14, 2013 | 09:45 PM
jds4181t's Avatar
jds4181t
is your vehicle auto
Old Dec 14, 2013 | 10:01 PM
SR71's Avatar
SR71
Lead Super Moderator
Looks like two different kinds of coolant got mixed together that didn't work well with each other and it coagulated.
Old Dec 14, 2013 | 11:26 PM
jds4181t's Avatar
jds4181t
if its an auto, it looks like the trans cooling line is leaking into the radiator, seen that happen a lot on nissan..
Old Dec 15, 2013 | 01:05 AM
350z-Na's Avatar
350z-Na
No, my car is 6mt
Old Dec 15, 2013 | 01:08 AM
350z-Na's Avatar
350z-Na
I already drained the coolant from the radiator plug. I still have the coolant in the block. How do i drain it from the block? I just remove the lower hose?
Old Dec 15, 2013 | 01:11 AM
350z-Na's Avatar
350z-Na
The colour of the coolant was green like usual.
Old Dec 15, 2013 | 01:41 AM
jds4181t's Avatar
jds4181t
i think an easy step would be to use a block tester
Old Dec 15, 2013 | 04:57 AM
350z-Na's Avatar
350z-Na
Can't really test it, since i'm doing full engine bay wire tuck. I noticed as well my cylinder #6 has blown spark plug seal. I'm going to scoop up a bit of the substance and mix in a cup of water, and do what Sean suggested.
Old Dec 15, 2013 | 07:46 AM
350z-Na's Avatar
350z-Na
Sean, what type of paper should I use?
Old Dec 15, 2013 | 07:58 AM
Sean's Avatar
Sean
Ideally you would use medical straining paper, but assuming you don't have that, use a 3m mask or a coffee filter.
Old Dec 15, 2013 | 06:52 PM
350z-Na's Avatar
350z-Na
Alright, thx a lot. I will check it out tomorrow.
Old Dec 15, 2013 | 07:44 PM
mr. sparco's Avatar
mr. sparco
Silicate drop out, the coolants been in the system for too long and is "spent." Do a search on it, turns into yellow crust over time. Usually kills the water pump if left unchanged for too long.
Old Jan 20, 2014 | 10:30 AM
zetosan's Avatar
zetosan
Hey man did you figure out what the yellow substances were? cause my thermostat gave up and i was changing and did a coolant flush and i also saw the yellow stuffs in the radiator through the cap. you think its anything to be worried about?
